Samsung Galaxy S25, Edge! FE! Ultra! & Accessories ..
What do you think is the nicest color S25 series?
  • Total voters
    206
coldspot
Thinking about getting that Samsung anti-glare screen protector later, anyone know if they'll put it on for me?
coldspot
Self applied the Samsung AR screen protector
Alignment was pretty spot-on
But had a bit of issue with my case (quad lock), because the case have a bit of "lip" around the bezel, casuing the SP to peel a bit.
Finally managed to tuck the SP nicely after a few tries
How's the clarity and vividness after you apply on it? Is it as good as never put the film?
AngelRomeo
Probably the only titanium black around so sharing pic😅
cause the black is ugly with the gold frame. if frame is silver i dont mind, but gold is like not here not there, hence the little vote on the poll.
and it also reminds me of huawei triple fold color..
https://www.hardwarezone.com.sg/tech-news-huawei-mate-xt-global-launch-date-18-february
initially i also wanted to get titanium black, but end up went for silver blue.
it took 2 weeks for me to consider
zhangwuji
Im loving the 50Mp ultrawide lens. The macro ability is solid. And the minimum focusing distance is so shiok.
saw your post and had to try it out.
really impressive.
Azrielsc
Just got home, couldn't resist to open the box. Immediately applied the Samsung Anti-Glare film protector for the front screen and Spigen glass protector for the rear cameras, fitted the Jetblack into a Spigen Thin Fit (Magfit) case. Now charging with Samsung 45W charger and a Ugreen cable, got the Super Fast Charging 2.0 notification. Turned it off and will wait for the weekend to go through the Smart Switch process.
eq2addict
Just got home, couldn't resist to open the box. Immediately applied the Spigen film protectors for both front screen and rear cameras, fitted the Jetblack into a Spigen Thin Fit (Magfit) case. Now charging with Samsung 45W charger and a Ugreen cable, got the Super Fast Charging 2.0 notification. Turned it off and will wait for the weekend to go through the Smart Switch process.
what film protector for the back camera ? i just notice scratches on my zfold's rear camera ring :sleep: cos its white metal ring
zhangwuji
spigen...
but must be careful when you're taking out the case.
one of my smaller camera's protector popped out when i took it out from the case.
nb.. zzz..
