- Sep 16, 2018
Hi Xiaofan,
Below is my floor plan.
Currently, i'm using 3 x Deco M9 Plus. One is inside my DB Box with my ONT, 1 is at living room lan port, and 1 is at bedroom 2 lan port. Coverage wise, every part of the house is covered including toilets.
However, i'm wondering if it's possible to have only 2 router? 1 at living room lan port and 1 at bedroom 2 lan port? If so, how do i connect the main router (living room lan port) to the ONT which is at the DB box?
Any help here is greatly appreciated!
Thanks!
In order for Ethernet Backhaul to work, the main router has to be in the DB Box in your case.
If your DB box does not block WiFi too much, I tend to think two nodes will be good enough: EB810v in DB box and HB710 in Bedroom 2 (which can cater for one 10G wired device in Bedroom 2).
You can carry out an experiment by removing the Deco M9+ in the living room to see how it goes.
