Samsung Galaxy S25, Edge! FE! Ultra! & Accessories ..
What do you think is the nicest color S25 series?
  • Total voters
    204
Rxgn
The samsung points like useless
No accessories to buy
2 years later then change to s27
What will u guys spend it on?
eq2addict
samsung ring lor... or watch. the points is mainly to buy their overpriced items. if u need fridge , tv , washer, can use the samsung points to deduct. i use my points to deduct off almost $200 off a tv while it was on promo a while back.. quite a good deal to replace my spoiled ( samsung) tv .
noinimod
anyone using the official kindsuit or silicone case, any feedback on them?
Not using it but went to play around with it in the Samsung physical store.
Kindsuit is fake leather. Should be polyurethane plastic material. It does not feel cheap like taobao fake leather cases, but durability seems like an unknown at this point. It's too expensive at retail price, imo. Poor value compared to 3rd party case brands.
Silicone case is nice to hold and touch. Reminds me of the Apple silicone cases. May have the problem where the silicone tends to 'stick' on the inside of your pockets.
Side note:
Installed the SC+ complimentary AR film screen protector at Samsung service centre
Big con is that the AR film is definitely more reflective than the glass screen, although still more AR than any standard non-AR tempered glass. I used the S25 ultra for a full week without any SP so the AR visual reference in my memory is still strong.
Just too bad the AR SP couldn't retain the same level of AR as the naked screen
rinchan22
Side note:
how durable would you say the SP is? (eg fingerprint marks etc)
Advancer
i swear by the anti-reflecting screen protector as the current one on my s24+ is still as good as new even after 4 months of usage. Of course cannot compare with using it naked, but it comes with fear.
eq2addict
samsung fake leather cases have a tendency to turn black on the areas that rub against something ( corners etc ) it happens on 2 or 3 of my previous phones. so get the black color or something dark. dun get light blue / orange
Advancer
I think that happened only to real leather cases and its called leather patina.
I used the grey vegan case last year and it did not turn black at all cos its not real leather since then.
eq2addict
mouldy is patina ? then i rather dun wan :ROFLMAO: no lah.. i got real old leather wallet that turn shiny smooth n oily?
the fake samsung leather is not liddat , it just turn blacky and cui / almost like falling apart. can see the plastic underneath also pengz
Milo Van
Side note:
Does the AR film trap dust or lint on it's surface? especially when pulling out of the pocket. Those normal non-matte kind of film tends to have this 'sticky' problem, hopefully this AR kind doesn't?
jess_sy
So far no issue. The coating is good!
eq2addict
abit white at the sides but all SP & case have it .
