解签 - Decipher of Divination lots from Temples
littlefishsea
hi everyone, recently went to gym at bugis to get guidance and advice regarding a mistake i made.
some info, i switched jobs but i did not disclose my previous job during the interview and i worry it will be reveaked and i'm super anxious. I asked gym for help at home using some digital lots (following SOP) whether I would be able to continue working at my current place even though i wasn't full
honest during the interview and still got the job and got lot 45 and lot 6. (i did confirm the lots with sheng bei each time)
A few days later i went to bugis to pray to gym for forgiveness and asked if the lots she gave me a few days ago was the intended lots, and i got sheng bei.
I proceeded to ask if there were anymore advice she wanted to add on, and i got sheng bei again followed by Lot 49 and lot 28.
so i'm looking at it as lot 45, lot 6, lot 49 and lot 28
i kind of interpret that GYM is telling me have patience and be honest when the time comes to face the issue
seeking advice, thank you
hellomello
Hi
Just follow my SOP and no need to listen to the temple staff if you want us to help you.
The draw lot SOP is here :
Extracted para that explains why some will get more than 1 lots:
Some may ask why need to do so complex steps, one lot is enough as GYM or the God of the temple 神通广大 one lot is enough. yes right GYM or the God of the temple is but we are not.
When GYM of the God has multiple advice for you, he will give you more than 1 lot and its like a jigsaw puzzle. Gym or the God can give up to as many as 10 lots for one advice. If one did not check if there is next lots and just left with 1 lot, we are not sure if the advice is complete and hence, unable to interpret correctly. or give you half interpretation then you come and say not accurate
(Its like calling someone and hanging up the call halfway )
There are reasons behind it but many dont know about it.
Hi Master Zhou and mgx, there is this guy that I like for a few months but I felt that whenever I talk to him, his response is so-so. So I've been thinking maybe it's time to finally let go of my feelings for him.
I asked guanyinma if I should still initiate contact with him. Ans: 1 sheng bei
Then I asked if guanyinma has any advice for me via lot. Ans: 1 sheng bei
I received the lots in this sequence: 25, 73, 77, 94, 97, 85. All confirmed with sheng bei until gym say no more lots
Quite shocked because first time I have so many lots. Pls help me interpret or advise if I need to change how I ask.
Thank you 🙏
mgx-alander
Thank you 🙏
sorry i am not well versed in multi lot ans, esp when its so long, i let zxx shu shu handle, please wait patiently
mgx-alander
hi, i am not too sure about digital lots, because digital lots are based on a computer algorithm that is pseudo random, so we are not able to tell u more about 45 and 6 since it did not came out from the lot in the temple
and i do not understand not revealing ur full job history is a problem, meaning u had a career gap in ur resume? i dun think this is smth to be worried about unless u lied about ur payslip? Since u are already employed in ur new place it should not be a problem?
what is ur exact worry, without context, we are not able to tell you the solution
littlefishsea
ah it's not regarding payslip. my concern is the contract did state that if there any omission is grounds for termination so that's my main worry.
ZhouXingXing
Thank you 🙏
Hi
Based on your question to gym, gym answer to you is a yes and further advice by lot is as below:
You may feel you taking initiative is not right or most appropriate actions but there are situations where you need to work accordingly to the situation and be more confident about yourself. try not to overthink to scare yourself.
although you feel that there are no progression but its just not the right timing yet
at same time take the chance to know him more too as what you see or perceive is not really the him.
You also need to take some time to understand or get to know what is his area of interest
there are also things that cannot just use see see to know more about him as he may only show the good side.
you also need to understand there are things like that mean like that 就是这样的,there are nothing much you can do on your end..
end of the day is cannot rush and has to wait for the right time to come and meanwhile take some time to understand him or what he like will help alot in your situation.
My take is:
you need to take some actions if not things wont move at all and to attract his attention, you need to roughly know what is his like or interests in-order to have more connections with him which can help both to progress. The entire process is 急不得 one.
Just to check if this guy is kind of quiet and introvert type?
mgx-alander
Hi
My take is:
At least got yes and the ending is still got hope but need time correct? :frown:
愿你们有情人终成眷属
ZhouXingXing
Hi
usually electronic lots are not considered accurate because you need to verify using sheng bei aka pua bei if the lot is the one Gym want to give you for your question. so now can only based on lot 49 and lot 28
and also for your question, we need to know like,
- if you have started working at the new place?
- if you have received offer from the new company ? if yes, have you accepted the offer?
hellomello
Hi
My take is:
Hi Master Zhou, wow you're very spot on. This guy is in between introvert and extrovert. He's quite chatty with me, I'm more introvert than him. We dated for a while last year, but he was not ready for a relationship due to some personal matters. We stayed in touch. However, when we talk, it's because I initiate the convo with him. If I don't initiate, he also won't start the convo.
Actually I have asked Guanyinma about him a few times, whether his is my 缘分, and got shengbei each time. (Actually come to think of it, quite silly to ask about 缘分 when I dunno this guy v well yet.) I also asked about a different guy I dated and got a straight NO, and really turns out that guy got red flag.
Last month I also asked Guanyinma for advice on the same guy. Received lots 31, 87, 4 (same SOP). Seems like her message is also to wait for the right time. That's why my heart feels 困境.
Dear mgx, thank you for your well wishes!
littlefishsea
Hi
Hi Master Zhou, yup I have already accepted and started at the new company for a while, but lately there were a few incidents that made me worry about this issue, so am I went to seek gym for advice.
ZhouXingXing
I see..
seems like he could belongs to the not so auto type and apart from waiting for the right time, gym also did mentioned that you need to know what he like or interest so you can better understand him and at same time, he will realised you "know" him so it would be opportunity for both to get a step closer.
If just waiting alone, nothing much will take place because he likely wont do much about it too
ZhouXingXing
Hi
I see.. from the 2 lots 49 and 28, it seems like previously you are kind of desperate to get the job which was why you committed the mistakes. However, dont think too much to scare yourself as when issues arises, will have someone to help you to cover over.
my take is: dont think too much about it just focus to get your work done and dont commit any funny mistakes (like those mistakes should not commit yet still commit kind), you should be safe unless got people go dig out the matter, even so, there will be people trying to help you in some ways.
ZhouXingXing
Cases received from PMs.
Case no. 1
asked about career where he got some issues with boss and thinking whether to leave the job or not. Asked Gym for advice and received lot 86.
My advice:
First need to think through if want to move or stay, if decided to move, can look for job while working and to ask Gym again when received new job offer.
One has to think and decide on the route to take first before asking Gym for advice, will be more fruitful this way.
Case no. 2
Used Sheng bei to ask if ok to travel in coming month - May. Using 3 sheng beis but only received 2 sheng beis (first 2 throw) and last throw is xiao bei. Draw lots and get lot 50 (did not ask if there is any more lot)
My advice:
Not recommend to travel since there is no 3 sheng beis straight and as for lot 50, it says something like dont go too far places (assuming Gym only want give 1 lot). otherwise, the interpretation would be different.
ZhouXingXing
I use the bei to ask if my ex company will hire me back.. and i got sheng bei..
But today i got the rejection email.. 🙁
Hi
Usually asking Gym 占卜type of questions, the accuracy is rather low as they often dont like or not willing to answer.
Example of 占卜 type of questions,
- will i get the job after attending the first interview
- will i achieve xx outcome etc..
and many more..
if asking about advice related questions, the accuracy would be high. For sheng bei asking advice related questions, usually is which option is good for me as i cant decide which suits me more etc...
Gym or other deity would rather answer or help those who had self help first but yet couldnt come to a conclusion, like think think but still lost or unsure type.
Reasons why Gym and the rest of the deity behave in such manner is because they dont want us (human) to develop a 依赖心 which will resulted in us losing the ability to think and decide when required and becoming 迷信 along the way.
Waterlily40
Hi Master Zhou, I asked GYM if the answer is yes then give me 3 sheng bei. I got 2 sheng bei and 1 xiao bei so I repeated the question. Again I get 2 shengbei and 1 xiaobei.
How do I intepret this? Thank you.
