RDNA4 RX 9000 series thread (Navi 4X)
Xeroze
I'm pretty satisfied with the performance of the 9070XT
Test Bench @ 1440p
7800X3D
Asrock Taichi 9070XT
32GB DDR5 6000Mhz CL30
Temps after 30mins of 99% GPU util:
55°C GPU Temp
85°C GPU Hotspot
86°C GPU Mem
Roughly 25% performance increase from my old 6950XT.
MHW benchmarks are with FSR 4 and Frame Gen enabled.
Almost the same as my case from 7800xt -> 9070 for the monster hunter wilds benchmark. From 24k score to 30k in the case of 9070, about 10% less than 9070xt which i wasnt above to get, but the improvement from fsr 3 to fsr 4 is pretty obvious.
Xeroze
Looking at the powercolor 9070 reaper... I guess by now the stocks are probably gone in sls
Yea probably. I got the second last one at 3-ish pm before my last post. Guy in front of me got the last 9070xt in the shop T-T
Richliao
Test Bench @ 1440p
7800X3D
55°C GPU Temp
85°C GPU Hotspot
86°C GPU Mem
Is fsr4 that much better?
Phen8210
The image quality is a lot better than FSR 3.1, its at the level of DLSS CNN model 3.8.1, but is behind DLSS transformer model.
Upscaling like dlss/fsr also takes care of anti-aliasing as well which is pretty much needed given the lack of modern AA solutions in Native.
Dongo0000
priceraster fpsRT fpsraster perf/$RT perf/$avg
5070 ti
1500​
126​
86​
11.9047619​
17.44186​
14.67331​
4080 sup
1600​
138​
95​
11.5942029​
16.84211​
14.21815​
4080
1610​
135​
93​
11.92592593​
17.31183​
14.61888​
4070 ti sup
1250​
120​
81​
10.41666667​
15.4321​
12.92438​
9070xt (reaper)
999​
119​
68​
8.394957983​
14.69118​
11.54307​
9070xt (best till)
1119​
119​
68​
9.403361345​
16.45588​
12.92962​
7800xt
649​
93​
35​
6.978494624​
18.54286​
12.76068​
7800xt (+mhw)
549​
93​
35​
5.903225806​
15.68571​
10.79447​
9070
899​
109​
59​
8.247706422​
15.23729​
11.7425​
fps for 1440p from hwu. if cannot buy under 1119 just wait until gpu + free game combo or gpu + free game + black friday discount. Otherwise just buy 4070 ti super. Note: you can maybe -$100 from 7800xt if it comes with monster hunter wilds.
Ratix0
Manage to get the powercolor reaper 9070 at the end of day after work. Xt completely out of stock, non-xt looks decently available though in a few shops.
Im mainly looking at the reaper for my itx build, so 9070 being 899 and xt being 999 kind of makes the non xt looks a lot better compared to us msrp. Xt costs 11% more and gets about on average 12-15% more performance. That is if you can find the xt at 999. With this, justified going one tier down to the non xt card.
Xeroze
Nice. I feel like there's abit of overclocking headroom as well.
noobiee
if the next batch comes in at "more than MSRP", then AMD is regressing again. nbcb
Yongkit
I wonder how many that grab 9070 series coming from Nvidia last gen GPU and how is your experience with your new GPU
Richliao
Personally, Amd to nvidia is not samsung to apple. Tried 4060ti and 6800xt...I rather use 4060ti with its dlss.
But now I itchy to try 9070xt due to its improved fsr4 improvement. However, amd cards all doesn't offer extended warranty right? ...or else I sure take gigabyte gaming oc with 4 years warranty.
Phen8210
Actually i wanted to, and here's my take on it. If you haven't manually enabled DLSS 4 transformer model to use its upscaling for every game, I think FSR4 will definitely be fine for you, and moving to AMD is definitely not an issue for those who only play on poorly implemented native and legacy TAA, of course this is just purely based on image quality, other factors to consider are things like how broad your usage is.
kappak
AMD 25.3.1 driver not good. make my screen flickering when swap game><windows
7900xtx
