Anyone tried slimming pills to slim down and worked?
  • Have you been Scammed?
feeltherain
Most sliming pills work by suppressing your appetite
if you don’t eat less and in calories deficit, then you still put on weight
in fact, you can lose weight without any pills. Just eat less and exercise more. As simple as that
eating less or don't eat is not feasible in the long run as body still need nutrients
PikaPika33
High Honorary Member
7 out 10 doesnt work
those that work most.likely you get side effects
dont bother
addict951
@feeltherain mm
It’s all about portion control.
Calorie intake > expenditure
you will become fat.
The opposite is also true.
You want 吃减肥药 you go google what happened to Pierre Png’s wife first hor. :look:
CCCustom
A former colleague of mine lost a lot of weight on Panbesy … I thought I’d give it a try, but side effects include palpitations and I was suffering from Hyperthyroidism which itself has palpitations as 1 of the symptoms … so decided better not … + this former colleague mentioned he got temperamental easily when he was on it.
This was quite a few years back story though … at the time Panbesy was a doctor prescribed thing … not sure if it’s still legal in 2025.
cosmothecat
Just reduce your carb intake and skip sugary and ultra processed stuffs.
Yes, this
a lot of people consumed unnecessary calories from sugar in drinks
also, in between meals they snack on potato chips. Big no no
rockerex
Go polyclinic get referral for weight loss clinic.. they have pills at subsidised rates ie ozempic
Thoreldan
Please dont skip exercising. Strong muscles and joints are important especially when we become older. Reduces risk of falling.
All these pills or diets are not good enough.
FORSTA
don't know what goes inside the pill and all the negative side effects comes with it. it's chemicals at the end of the day. just eat less exercise more.
PikaPika33
if i tell you your body doesnt need as much as you think?
or evem feel?
yes our body lies to us, most of the time.
to retain as much fats and gain as much reserves as possible.
eve if you lose them, your body will be desperate to gain them back
use our brain, look at the scale and your body measurement
Laguna123
think these sliming pills will destroy your internal organs first before slim u down. Remember slim10 saga?
