RDNA4 RX 9000 series thread (Navi 4X)
xonix
Based on the
FSR 4 seem to be able to deliver comparable image quality at one level lower than FSR 3, that effectively makes the 9070 XT much faster when doing an apples to apples comparison in terms of image quality, and the gap is simply going to widen.
Really excited to see how FSR 4 develop overtime, one day it will match Nvidia transformer model which has stunning image quality.
Definitey a huge jump in quality from what they had before. Previously, I would rather lower graphics settings than turn on FSR to hit fps target. Now with FSR4 ? I might consider it.
xonix
Based on a recommendation I saw in a reddit post, I have disabled pcie power savings in the control panel.
So far, haven't encountered " driver timeout" while web browsing or watching youtube. 🤞
Everything else is stock settings other than disabling zero fan rpm
xonix
AMD Software: Adrenalin Edition 25.3.2 Optional Update Release Notes​
https://www.amd.com/en/resources/support-articles/release-notes/RN-RAD-WIN-25-3-2.html
Highlights​
  • New Game Support
    • Assassin's Creed Shadows
    • The Last of Us™ Part II Remastered
  • Fixed Issues and Improvements
    • Incorrect gamma is exhibited while playing Counter-Strike 2 and using MSAA x8 on Radeon™ RX 9070 series graphics products.
    • Intermittent application crash may be observed in Indiana Jones and the Great Circle when settings are set to "Very Ultra" quality and Path Tracing is enabled. Users experiencing this issue are recommended to use the default Ray Tracing settings as a temporary workaround.
    • 3rd party tools that rely on our ADL SDK for detecting ROPs count will incorrectly report 64 ROPs.
    • Lower than expected performance may be observed while playing Assetto Corsa Competizione on Radeon™ RX 9000 series graphics products.
    • Intermittent system or application crash may be observed while pressing Alt-Tab during gameplay on some AMD Radeon™ Graphics Products such as the Radeon™ RX 6000 Series.
    • Intermittent system or application crash may be observed while using multiple high refresh rate (+120Hz) monitors with HDMI connections.
    • Windows Update may overwrite the installed AMD Software: Adrenalin Edition with an older version of the graphics driver on Radeon™ RX 9000 series graphics products.
Developer Updates​
  • AMD Radeon™ Developer Tool Suite (RDTS) update with support for AMD Radeon™ RX 9000 Series graphics cards is available now. Learn more about all the latest updates to our developer tools here.
  • AMD FSR 3.1 is now supported in over 110 available and upcoming games. Update your games with the AMD FidelityFX™ SDK to have our latest technology, including AMD FSR 4 support.
  • Stay tuned to the GPUOpen news feed and social channels for the latest updates for developers.
Known Issues​
  • System crash may be observed due to a memory leak when using SteamVR on some AMD Radeon™ Graphics Products, such as the Radeon™ RX 9000 series. Users experiencing this issue are recommended to turn off Motion Smoothing in SteamVR settings.
  • Performance logging notifications from AMD Software: Adrenalin Edition™ may appear while using the Right Alt + L hotkey if the Microsoft® Windows® display language is not English.
  • Intermittent crash of AMD Software: Adrenalin Edition™ may be observed while playing Marvel's Spider-Man 2 or Ratchet & Clank: Rift Apart with AMD Image Inspector enabled. Users experiencing this issue are recommended to disable AMD Image Inspector as a temporary workaround.
  • Lower than expected performance may be observed when using YouTube on the Microsoft Edge web browser immediately after a driver install. Users experiencing this issue are recommended to restart Microsoft Edge and relaunch YouTube as a temporary workaround.
  • After using the AMD Cleanup Utility for Windows®, the AMD Bug Report Tool may appear intermittently during a new driver install on AMD Ryzen™ 7000 and above series processors paired with AMD Graphics Products.
  • After completing a driver upgrade on certain laptops, users may experience intermittent failures for the integrated camera to start. Users experiencing this issue are recommended to use the AMD Cleanup Utility for Windows® and use our previous recommended driver, available here.
  • Stutter may be observed while playing games with some VR headsets at 80Hz or 90Hz refresh rate on some AMD Radeon™ Graphics Products such as the Radeon™ RX 7000 series. Users experiencing this issue are recommended to change the refresh rate as a temporary workaround.
  • Installation progress may persistently display 0% while installing chipset drivers using AMD Install Manager.
  • Installation progress may persistently display 0% while installing AMD Chat within the AMD Software: Adrenalin Edition user interface after upgrading to AMD Radeon RX 9000 Series graphics products.
Steinheausser
My monitors are not DP 2.1, just worried that for some reason the GPU might only allow 2 DP ports at the same time. The wording on the website leaves some room for doubt. Probably could've emailed PowerColor tbh now that I think about it.
Anyways, good news for folks who pre-ordered from Techyard. For reference, I pre-ordered 9070xt on the Friday Morning after release. They've notified that they've received my 9070XT reaper and will be arranging delivery today or next business day. Hopefully they come through. :)
xonix
Do update your experience with the card after you install it, I am ( still ) having weird problems with non XT version.
darkmatt
Can't find the original post for the driver timeout issue. I also experienced it.
Check yout GPU overclock settings.
I was running at 115% power limit and kept running into that issue.
I lowered it to 105% and no issue.
xonix
SIgh...
rx 9070 + 25.3.1 / 25.3.2 > gaming no problem, randomly driver timeout on normal desktop use
rx 9070 + disable pcie power save > gaming no problem, less driver timeout on normal desktop use
Trying tonight with driver only, without Adrenalin. Never had such problem before, more issues when not playing games 🤪
vironix
115% means Ur not on the 9070XT right?
xonix
I am not even thinking of any overlocking at all. Stock settings and I am still getting it.
Ratix0
So on launch night I preordered from techyard the powercolor reaper 9070xt. I was half expecting this to preorder to get cancelled. Got a message from them this morning that they are delivering tonight.
Already bought the 9070 on launch day because the xt is out of stock.
Guess now I will have a 9070 and a 9070xt reaper
xonix
Now I have a 9070 and a 9070xt reaper
So you pre-ordered both thinking one of them will get cancelled ? Actually I think AMD is not having the same stock shortage issue like Nvidia ( chips goes to AI instead ) . The demand for their 9070 series is just much higher than they are used to compared to rx5000/6000/7000 series.
Phen8210
Yeah, AI upscaling demand is quite high and not to mention a free monster hunter wild copy where the game will force any outdated pc to upgrade, perfect scenario :LOL:
Ratix0
Preordered xt from techyard, bought non-xt (xt were out of stock) on the day itself.
Guess i'll upgrade to the xt and try to sell off a 2 week old non xt model.
xonix
I am slightly disappointed my rx9070 standalone purchase doesn't qualify for the free game.
xonix
Should be quite easy to sell off, given the high demand. Of course, depends how you mark up :p
