CPU temp while playing helldivers 2
Vanyel
saw the temp at 84-97deg while my boy was playing...
14700kf
4070ti super
tecware vxl casing
8fans + a 240mm aio arctic liquid freezer III
only this game will become so hot...searched abit online seems quite a few ppl with this issue...
not sure whether to change cooler just for this game......
thoughts and suggestions anyone for a fix?
Vanyel
the 97deg was achieved under aircon on in the room
now idle is
i cannot add anymore fans liao
fan profile
Phen8210
How many watts is it drawing when you play helldivers 2?
Also, I think that's a tecware VXL case not montech.
Which fans are intake?
If the setup has no issues, just set a power limit in bios.
Vanyel
haha sry tecware, montech the psu i type salah
i follow this guide?
Psychedelic Senses
14700kf
4070ti super
tecware vxl casing
I have dogshĂ­t CPU temperatures for this game too. The latest update increased CPU usage as well for the bot faction because of their increased intelligence. Devs claim that players will 'take a small performance hit' but that's bullshĂ­t because I got my fps halved instead when things get intense. This game is just brutally CPU intensive and with every patch adding new enemy variants the CPU usage is just going to climb.
I hit 103 degrees peak without AC on when playing against the squids before (urban environment map) until I did some thorough PC cleaning 2 months ago and the temps dropped back down to 'decent' levels but then my CPU is a little old already and a known hot chip. Even after doing that my CPU averages late 70s to 80s in this game. CPU usage and temps scale with difficulty levels because the higher you go, the more enemies spawn and I always play on the hardest.
I think the kernel based anti-cheat is also contributing to the high CPU usage as well. City biomes hit the CPU harder too with average fps dropping by at least 10-15. Every update that drops new enemy types is going to inevitably run worse, it's a known trend for this dev. Used to have much better fps back then and now it's just not as smooth anymore. Really hope they can optimize their game better.
Vanyel
Think u can try searching for ur mb undervolting guide
It worked for me
Fps still around 90-110
Not sure if dropped abit or didnt
soreloser
ur CPU is running at insane temps lol, think you should try undervolting like the other guy did
KleoZy
That's good for @Vanyel to undervolt. anyway additional info for those using Arctic Liquid Freezer III on Intel.
This can improve temps.. but will need to purchase though.. https://www.arctic.de/en/Intel-LGA1700-1851-Offset-Contact-Frame-Mounting-Set/MPSAS01261A
I have tested it when Arcitc recently sent me this contact frame.. I am able to drop temp even further by 8°C on load non aircon. At load max 83°C I7 14700K
More info here https://hwbusters.com/cooling/dropp...s-5c-with-an-offset-mounting-kit-by-arctic/6/
tsteo77
14700kf
4070ti super
tecware vxl casing
Turn off turbo boost frequency can reduce good amount of temperature.
xonix
With all the amount enemey AI especially the higher difficulties, cpu usage usually stays around 60-70% for me. I undervolt my 5700x3d ( with TT AK 120 mini ) , temps are about also around 60-70 ( non air con room )
tigerwoods
14700kf
4070ti super
tecware vxl casing
wait til you play Rise of the Ronin, a badly optimised game
PC become a toaster running 80c constant
Psychedelic Senses
I think is game issue coz blackmyth wukong and mh wilds dun even exceed 85deg much
And helldivers 2 has no raytracing
Same, all other lighter games, CPU is just at 60+ degrees, or 70s max, it's just this game being an anomaly.
soreloser
Honestly it's not the game, it's your cooler is not sufficient enough to allow your cpu to run a heavier workload, so any CPU intensive game like Helldivers will cause the same issue.
Highly recommend to undervolt so that you don't need to spend any money
Phen8210
Yeah, if you cant run game and keep temp low... full load how? Some games build shader cache use 100% CPU usage.
Reduce your power limit to below 100W.
