- Sep 16, 2018
Thank you.
Just to check if I have a switch? Then I can convert from 1 input to 4 output at the DB box right?
Yes, but most likely your existing switch is capable of only 1Gbps so that will limit the second HB710 and other room LAN ports to 1Gbps.
You can of course upgrade to 2.5G switch (say around S$79 for TP-Link TL-SG105-M2 when on offer), which will limit the second HB710 and other room LAN ports to 2.5Gbps.
Or you can get mixed 2.5G/10G switch (at least S$100 with dual 10G RJ45 ports and quad 2.5G ports). In that case, probably it is easier to use EB810v as main router (10G WAN, 10G LAN, three 2.5G ports).
