[CONSOLIDATED] Myanmar/Bangkok earthquake
Level42
This person confirmed never experienced earthquake before. Does she know how scary it is to stay in swaying building? We all know Japanese buildings can withstand earthquake but we can't say the same for other countries.
The point is, nobody can make it out on time if the building does collapse. My Taiwanese colleagues said there is no way to predict how the building will break up. Sometimes it’s broken off at the upper portion, and the people at the lower floors are fine. Sometimes the building collapsed like the BKK one. Then those at the lower floors are unlikely to survive.
popdod
It's good advice but really Captain Hindsight horse back cannon.
Majority of tourist and Thai people have never experienced earthquake before. If it were me, I would have made my way down the stairs instead of staying under table.
that’s why is easier to comment at home comfort and slowly analyze. :s13:
these influencers really tok cork sing song. :s13:
EDMW-Hates-Me
She said she stayed in Taiwan. Prolly briefed this way and it's similar to the SOP recommended around the world. Scared then follow the experts who have analysed the best chance of survival. You have proof that your method is safer?
She is just sharing the knowledge so everyone can learn. Where got captain hindsight horse back cannon?
HirotoXeno
don't even try to convince other singaporeans .... it won't work
entire circuit breaker 2020 , less than 5 edmwers stored drinking water
everybody else expect wakeup use finger effort turn tap flick switch is guaranteed
Got alot stored toilet papers .
fortunecat
Why so coincident, all the youtubers go bangkok at the same time?
really huat for them... can milk from this earthquake make videos about it..
There are hundreds of thousands of YouTubers in this world, nothing strange for a couple of them to be there, which is a popular tourist destination? Probably will be the same thing if it happened in Taiwan
PhantomOpera
I would also try to run out of the building if I could. Only in Japan will the buildings not collapse, but not in Taiwan or elsewhere. Stay underneath the table is to avoid falling objects hitting your head. But if building collapses, and you are trapped inside, it’s gg liao
henghengonedragon
Ran out easy to be hit by falling debris and died.
henghengonedragon
Errr.... unless it is war, earthquake, water contamination, I don't think it is necessary.
3G SAINT
If collapse higher floor have high chance survive,low floor mati first as many concrete structure will fall down on the base...;)
