Apple Store vs Apple Authorised Reseller
bystanderbloke
About to join the Apple ecosystem,so I need info from Apple users here. Any difference when u purchase Apple products from Apple Store vs authorised resellers (Challenger, Harvey Norman, Courts, etc)?
For example, if I buy an iPad from Apple Store, I get to have a free 3-month subscription to Apple TV. Do i get the same subscription if I were to buy a similar product from its authorised resellers?
Would be great if you folks could clarify here.
reddevil0728
yes you will get to enjoy the same free sub.
I think the main difference is, apple provides 14-days return but resellers don't.
Apple almost never provide any discount as products are price controlled. resellers may
chopra
For ip16, apple store and challenger are selling at 1299 and 1097 (member) respectively. Is there a catch?
ragnarok95
Senior Moderator
Senior Moderator
$200 is alot. I wonder how many ppl know this hack ma
Outside apple sellers are always cheaper than apple store. Buying from apple store mean you still have 14 days to return which is not the case for iphones selling outside of apple store. You are subject to their own term and conditions instead of Apple and most do not entertain 14 days return.
Example, iphone 16 is selling for S$1299 in apple store and the same iphone is selling for S$1008 in mistermobile shop.
Then you have to decide which to get. This is not even a hack.
chopra
At 200$, most ppl will forgo e 14d return
This is also not common across products.
Jurong640
I think it's the 14-day return policy that makes the difference. For me, an Android user, wants to try the iPhone if it really suits me, the 14-day return policy excites me. I can try first without burning huge money, I benefited from this from my MacBook Air purchase, returned and bought MacBook Pro instead. Same for iPhone 15, I returned the phone after trying out and found that it doesn't suits me.
erwinrommel
You can buy from Apple Store and use and return it within 14 days... then get from the retail store if you wanna save the money.
badab1ng
i bought an ipad from shopee flagship apple store. volume buttons started malfunctioning - i took it to apple store in orchard. they replaced it with a brand new ipad no questions asked (it was still under the 1 year default warranty). so doesn't matter where you buy your apple product from. its warranty will still be honoured by the official store.
reddevil0728
yes for sure. but the replacement i think is because is ipad or certain components they don't repair, just replace
AngelRomeo
usually apple products i dont buy at apple store due to the market price
AngelRomeo
Sometimes the price is worth paying, e.g., if you want to try a product.
but not for me, if try i go apple store to try. for apple products usually i normally wont even try, as i already used before the previous gen ones, so for me apple authorised reseller is still the way to go.
