Anyone here staying in 2 room BTO?
Should we move it to HomeSeekers and HomeMakers?
  • Total voters
    49
  • Poll closed .
crystalnox
Sadisticnoob
Can this fit a queen size bed?
you have the full spec ?
I think the bed will be leaning towards the wall on the down side. but your entry way will be small
Techno Pride
update:
Also if it a good idea to put a magnet bar at the knife location?
The iconic KDK/Panasonic fan. Must be very careful when cleaning, cannot use water. The fan blade at my current home is peeling at the edges.
I'll buy a new one at TPY Courts ($100+) after key collection and bring over.
Techno Pride
full spec of?
I'll need to measure the bedroom on key collection date. As for queen size bed, the standard measurements are 152cm x 190cm
Sadisticnoob
full spec of?
You need account for the platform that you put the bed on unless you’re just putting it on the floor
Techno Pride
Yes, but won't have a lot of space left
Suggest to check your bed frame size, then draw over the floor plan, to see remaining space
One example below, 202 x 155cm
https://www.fortytwo.sg/leia-queen-faux-leather-bed-frame-black.html
ah got it. I'll need to measure the actual internal dimensions of the room on key collection date.
Have visually checked the top left pillar at 1st floor, looks thick.
The_King
wongminmin
That my cooker hood, if the food I cook I knew will make too much smoke or smell I put on table then start to cook, so all blow outside.
The lady finger i cook no smoke , very strong smell so I put on floor to have extra space but I use the oil spatter shield to prevent oil from how spatter
Hahahahha
which 1 better?
