Hi, just started looking for landed..
With so much variables for landed, I find it difficult to make a judgement.
for example, if there are 2 houses for sale, in the same enclave, same cost and same size of land.
1 is 10year old rebuilt from original site, has twice the amt of GFA ie approx 4500sqft
The other one is a brand new build, but only half the gfa of 2600. Better location and unblocked view.
which one will you choose?
questions you should also ask yourself.
1. do you drive?
2. how far away are the houses away from amenities (eg: bus stop, supermarkets, neighbourhood stores, etc)
3. how many pax will be staying with you
if your answer to question 1 above is yes and your family owns 1 or more cars, then question 2 is quite irrelevant. Question 3 becomes more important as if you have more pax staying, then more space and rooms will be better. If only 2 pax are staying, then it makes not much difference but the smaller house might be easier to upkeep if you're not planning to hire a helper or getting a part time helper/cleaner.
Personally, unblocked view is not important as how often are you going to be standing outside and "admiring" the views? With SG's weather, you're likely to encounter either sun or rain most of the time during the day. Even at night, the humidity will likely make you want to just want to relax indoors with aircon turned on rather than outside.
But you mentioned 2600sqf for a brand new built doesn't seem right as these days, developers will try to maximise the land and buildable area rather than keeping the building smaller than what is allowed. Maybe you can share the locations of the 2 houses as well if you don't mind.
