The Hair Thread - Part 5
Horiv3
Hi guys where do ya all shop for hairspray nowadays? I recall there was a seller here selling hair products (TPJ) in the past, but looks like he's not active anymore.
Also i realised taobao can't ship hairspray to us, so no idea where to shop really.
focus1974
i do shoppee the schawarfff osis... or something like tat
CrunchTime
What hair shampoo do you all use / recommend? I don’t mind splurging a bit if it’s a good. Was previously using Morris Motley shampoo but I guess MM isn’t very good now?
Any recommendation? :) In shampoo buying mode now
Scarlet Tea
Anyone tried volume rebonding before? Does it give your hair more lift? Cos my hair is very thick and heavy. When styling my hair I wld use sea salt spray and hair dryer for the lift. But after sometime outside may hair start to flatten again
Piped Piper
What products can add more volume to my hair? I have type 1A hair and sea salt spray doesnt really work, my hair will still fall flat after a while.
sansanjikikut
Can try Flagship pomade and shear revival products for hold endurance. Especially in our humid/hot climate
currently trying out moroccanoil texture clay for my short hair. So far able to keep the style shape within the day
Morris motley new balm is not as good as the og (in term of hold and endurance). But the scent is just next level
Piped Piper
Hi guys, any recommendations for shampoo and conditioner for thick straight hair with oily scalp? I will be using nizoral shampoo two days of the week so for the other 5 days i need another shampoo and conditioner. Currently using Head&Shoulders.
subprimelive
Paul Mitchell tea tree works well
sansanjikikut
Try using a light hold non oil based product with organic ingredients then wash off with warm water only. No need for shampoo
dev_stg_prd
I have a silly question.. what is the modern equivalent of Brylcreem?
Or should I just use a leave-on conditioner?
Some hold( nothing too much if you need what is the hold level of Brylcreem ) would be good but I need it to be flexy if you know what I mean.
