BlackWing1977
- Mar 1, 2006
Everyday on shopee got new vouchers one...Got voucher price no good, good price voucher used up.
Missed the whole sale.
How about these?
https://www.hardwarezone.com.sg/fea...rds-2021-editors-choice/best-gaming-headset-1
Many of them are still available for purchase, even if we've reviewed them in 2021.
For your consideration![]()
Not much can beat the Nova 7? Maxwell, Nova Pro?
Thanks bros and honored that dr beejay reply moi.hyper x cloud revolver s is already out of production, but it has a TeamSpeak and Discord certified noise cancelling mic, which is great for transmitting clear lag free instructions to gaming buddies
it has a 70mm ear cup, which is bigger than XM5 and ugreen studio pro (both 65mm)
i don't know about the newer models because this one served it's purpose very well, which is to win multiplayer fps games
It does not have ANC, but since you're gaming on windows, you can use Krisp and select either your laptop mic or gaming mic to be the anti-noise cancelling source input. So with a laptop, you don't need an ANC headphone. krisp works with voicemeeter, and you can connect multiple wired and wireless headsets to the laptop, and they will all have lag free ANC, individual EQ and individual volume adjustments
my hyper x cloud revolver s is around 5 years old and still works. it actually sounds better ugreen studio pro but i could get nearly identical sound by boosting treble by 12dB and bass by 6dB on my ugreen
Mod the Sundara with a short cable then cable tie to a bluetooth adapter that can output balance and have Ldac?
Use BTR 15?
This one extreme budget DIY
Edit: Sundara sounded the best using a Balance cable (4.4mm vs XLR?), a good DAC/Amp stack etc
hehe can compromised a bit hoot high end IEMs to pair with bluetooth adapters? Got some open/semi open ish swee swee deThanks for the serious reply and not claiming something under $100 can be made to match a $460 Hifiman without trying the latter.
Not saying that it cannot or that its bad, but I did mention the Space One Pro and Sony XM5 not offering what I want and they are $260 and $470 respectively despite supporting LDAC.
I do actually have a BTR15 and two Radsone ES100. Attaching them to the headphone is far from elegant, but the biggest obstacle is actually finding a balanced cable that is of the right length and terminates in two right angle 3.5mm
Very sad that after all these years, audiophiles still dismissing LDAC and not asking to be rid of wires for full sized open back listening. And the only reputed brand in this space (Sennheiser) hamstringing their Momentum series by refusing LDAC
Having a stack only does so much to the sound signature. Without them, something like a Sundara or HD800 is still miles better than things not made for trained ears
hehe quite hard to see new 70mm dynamic driver headphones liao....if wanna go big will have to go Planar or Electrostatic liao..confirm and chop bigger than 70mmmy own experience is that headphones with bigger sound drivers usually sound better
hyper x cloud revolver s - 50mm
sennheiser hd620s - 42mm
sony xm5 - 30mm
ugreen studio pro - undocumented but should be comparable to xm5 because the closed back dimensions are almost identical
my 5 year old hyper x cloud revolver s sounds better than the ugreen studio pro. i can use EQ to make it close to hyper x, but there's a qualitative difference that can't be compensated due to the smaller driver
so i'm confident your hd620s will sound better than ugreen, but whether it beats headphones with bigger sound drivers is worth discovering
The tuning plays a big part actually, size of driver is not everything, driver quality also plays a part... Sennheiser been in the audio business for a long time... so generally their build quality and tuning more or less will not have any major issues...my own experience is that headphones with bigger sound drivers usually sound better
sony xm5 - 30mm
Next time can wear 2 speaker driver on ears... super large dynamic drivers..hehe quite hard to see new 70mm dynamic driver headphones liao....if wanna go big will have to go Planar or Electrostatic liao..confirm and chop bigger than 70mm![]()
hehe historical headphones got gigantic ones deNext time can wear 2 speaker driver on ears... super large dynamic drivers..![]()
Any feedback on OneOdio headphones?my own experience is that headphones with bigger sound drivers usually sound better
sony xm5 - 30mm
which oneodio model is this? is it priced around $50?Any feedback on OneOdio headphones?
Pro C, Pro 10? Kind of the entry level for wired and wireless.which oneodio model is this? is it priced around $50?
i am waiting for china to introduce next-gen MEMS based headsets. this tech is what's needed to further reduce weight, dimensions, costs and yet preserve good performance. MEMS based earbuds are still too expensive for mass consumption because it's quite new
hehe solid state sound also a bit different from other driver type...will need to get use to them too...give it some time bawhich oneodio model is this? is it priced around $50?
If wire look for Monitor series ba?Pro C, Pro 10? Kind of the entry level for wired and wireless.
Very plastic feel.Any feedback on OneOdio headphones?
