it's a close fight , based on the sample counts and results , we will be seeing Dr.Chee in parliamentFinal results for some GRC released, but Sembawang SMC still counting...?
PLS GG?
Weil, if they could introduce it, they can remove it too.but if they gotch the mandate... they ish can change the rule and remove ncmps... right??![]()
Only applies to things mentioned in parliamentParliamentary privilege = cannot tio sue right
i think rule is 1 from grc and 1 from smc
Poh li san need to pull up her socks
I think the only reason why it was a competitive race in Sembawang West SMC was because Poh Li San has not been doing a good job on the ground. There can be no other explanation why PAP garnered 67% of the votes in the surrounding Sembawang GRC but only 53% against Dr Chee in the SMC.
I believe it is more of Dr.Chee appearing on the printed newspaper over the past 5 years on what he has done in bukit batok and what he has done for the underprivileged (treat them a meal at his restaurant)I think the only reason why it was a competitive race in Sembawang West SMC was because Poh Li San has not been doing a good job on the ground. There can be no other explanation why PAP garnered 67% of the votes in the surrounding Sembawang GRC but only 53% against Dr Chee in the SMC.
For the next election, confirmed this will be absorbed into a GRC, since its performance is worse than the surrounding area.I think the only reason why it was a competitive race in Sembawang West SMC was because Poh Li San has not been doing a good job on the ground. There can be no other explanation why PAP garnered 67% of the votes in the surrounding Sembawang GRC but only 53% against Dr Chee in the SMC.
Feel sad for Dr Chee sia
