MochaMaverick
- Dec 2, 2010
I also applied SBF in Feb exercise, also failedfail again, my sbf application.
july it is then
july it is then
realized the chance very lowI also applied SBF in Feb exercise, also failed
this matter $$$$$cement screed not cold and slippery meh?
i prefer micro clay floor and marble gum instead
reno only is 9 khow much did you all spend on renovations
how heya in term of coverage or speed in mrt? u now using which telco?moi also got beo a bit, till nao the ant company moi feel the only one that moi will buy, if buying this type of wardrobe.
just purely moi personal opinion.
【淘宝】7天无理由退货 https://e.tb.cn/h.6OFVd1sFhUwaVyh?tk=ydftVVLTMbv HU108 「蚂蚁盒子免安装衣柜家用卧室简易约儿童衣柜组装大容量出租房柜子」
点击链接直接打开 或者 淘宝搜索直接打开
even for normal bto, for single to kena 2 room flexi is super low. sbf is like 0 chance. this video got explainrealized the chance very low
5% chance
https://sg.shp.ee/usqp6m6For those staying alone and does cooking, which rice cooker did u buy ? Most I saw online are more suitable for big family
The first rice cooker when I move in. I like the small and compact but problem is the glass lid doesn't have a small ventilator hole for the steam to spout during the boiling process,
Got small ones. 大 also can 当小用。Get a normal one if you intend to do meal prep.For those staying alone and does cooking, which rice cooker did u buy ? Most I saw online are more suitable for big family
anything as long as its under promoFor those staying alone and does cooking, which rice cooker did u buy ? Most I saw online are more suitable for big family
Wow, didn't know it doesn't have hole for ventilation, that's not a good rice cooker. Have it in my wish list, thought of buying it when my current one spoil, thanks for the heads up.The first rice cooker when I move in. I like the small and compact but problem is the glass lid doesn't have a small ventilator hole for the steam to spout when during the boiling process,
Ends up spilling over the pot.
So I end up wait lift the lid several times to let the steam out put manually then cover it back until the boiling process is over. My only compliments is my basmati rice looks good when finally cooked.
Eventually I gave up after a couple of months and replace with Philips.
Bought this at Amazon for $39 limited time offer
https://shopee.sg/PHILIPS-3000-Seri...-cook-Bakuhanseki-pot-i.269639798.22076374954
Recommend bed frame, this one only $70, and retractable, if you worried about bed taking up too much spaceAnyone sleep on sofa bed? Just wipe down, no need to wash bedsheets?
Agreed. Might be a little big for one pax. But I can't resist the good deal at that time.Wow, didn't know it doesn't have hole for ventilation, that's not a good rice cooker. Have it in my wish list, thought of buying it when my current one spoil, thanks for the heads up.
0.54L is too big for me, my current one is 0.3L which I don't even use half of it to cook rice![]()
