Recommendations for 27" OLED monitor?
zensushi
Moderator
Moderator
Hi! I placed an order for new PC on a whim.
What's a good 27" OLED monitor for a 5070Ti GPU, please?
From online searches, seems like it should be either of
  • MSI MPG 271QRX QD-OLED
  • Asus ROG Swift PG27AQDP
What are the pros & cons of the above pair? Any other/better recommendations?
GotBetrayed
Rog 27 UCDM
Alienware AW2725Q ordered 2 of these for my 5070ti setups
Yongkit
the GPU can run 4k for sure only is dpends on game titles and expected refresh rate.
just reshare the following which i post in the gaming monitor thread on 27in 4th Gen QD OLED:
4K 240Hz QD-OLED Monitor Comparison (2025 Models)
FeatureASUS ROG PG27UCDMMSI MPG272URXSamsung Odyssey G81SFAlienware AW2725Q
Panel4th-gen QD-OLED4th-gen QD-OLED4th-gen QD-OLED (matte)4th-gen QD-OLED
Size/PPI27" / 166 PPI27" / 166 PPI27" / 166 PPI26.5" / 166 PPI
Brightness (SDR/HDR)463nits / 1000+nits257nits / 963nits273nits / 1006nits273nits / 1031nits (Dolby Vision)
Response Time0.327ms (avg)0.339ms (avg)0.325ms (avg)0.327ms (avg)
PortsDP2.1, 2x HDMI 2.1, USB-C (90W)DP2.1, 2x HDMI 2.1, USB-C (98W)DP1.4, 2x HDMI 2.1DP1.4, 2x HDMI 2.1, USB-C (15W)
HDR SupportHDR10, Dolby VisionHDR10HDR10+HDR10, Dolby Vision
CoolingBuilt-in heat sinkGraphene coatingHeat pipes + grapheneActive fan
Anti-GlareGlossy (AR coating)Glossy (AR coating)Custom matteGlossy (AR coating)
Color AccuracyΔE 0.76 (P3)ΔE 1.04 (P3)ΔE 1.27 (P3)ΔE 0.7 (P3)
OSD MenuUser-friendlyFunctional but basicHighly customizableClunky navigation
DesignROG "claw" stand, RGBMinimalist, flat baseMetal chassis, RGB lighting30th-anniversary "tumbler" design
Price (Est.)$$$$$$$$$$$$$$$$
Pros & Cons Summary
ModelProsCons
ASUS PG27UCDM- DP2.1, Dolby Vision
- Best brightness (SDR/HDR)
- Clean OSD
- Glossy screen reflections
- No advanced cooling
MSI MPG272URX- DP2.1, 98W USB-C
- Affordable
- Solid color accuracy
- Low SDR brightness
- Conservative HDR tuning
Samsung G81SF- Matte anti-glare
- Dynamic cooling
- High HDR adjustability
- No DP2.1
- Complex OSD
Alienware AW2725Q- Dolby Vision, best HDR peak
- Unique design, active cooling
- DP1.4 only
- Green tint in P3 mode
- Expensive
Key Takeaways:
  1. For Competitive Gamers: ASUS (DP2.1) or Alienware (Dolby Vision).
  2. Bright Room Use: Samsung (matte coating).
  3. Budget Pick: MSI (best value).
  4. HDR Creators: Alienware or ASUS (Dolby Vision).
fkchon
It really depends on whether the games you play can benefit from high refresh rate or not. 240Hz is definitely too slow for me but I also don't want to go below 4K.
If you value visual quality and high resolution desktop experience then go with a 27" 4K 240.
If you play a fast fps game then 27" 1440p 480/500Hz. Some games like Apex Legend and COD doesn't go above 300fps so buying a high refresh monitor doesn't really help.
GotBetrayed
4k240hz 27 is the sweet spot now, very sharp.
-Synchronicity-
Prices still a bit high for me to swallow. Especially when OLED has a life span.
ATM, I would much rather pick a 27" mini led monitor instead until the prices come further down or if the tech further matures to last longer.
And not like I don't have any OLED products. Got a LG c2 2 years ago to see what's the fuss all about. While good, I don't think I would pay a similar scaled down price for a smaller monitor.
Yongkit
Life span on monitor is not really a concern honestly, no matter which monitor tech there are always rma request even before warranty expire. The only care of OLED was probably more frequently need user intervention compre other monitor tech.
zensushi
Moderator
Moderator
2725Q is flat. Waiting to get mine hopefully this week.
I may go for a 32" monitor since I am going to spend up to $2000 on it. 😅
Head pain from reading up on the various models. The minute differences in models with the slightly different letter-combinations are doing my head in.
GotBetrayed
Wa budget so high. I bought 2x AW2725Q for 2k.
-Synchronicity-
That's true if I'm only gaming. But I'm not. Text clarity also another issue.
-Synchronicity-
1440p will have text fringe yes but it is not visible at 4k
Right. And it's questionable to me to pay so much yet have to deal with text clarity issues.
This is why I'm perfectly happy with mini led until prices drop further or if it improves longevity.
Yongkit
yeah i do agreed on your perspective.
i persoanlly still going oled because i wanted to avoid blooming in IPS panel even miniLED can exceed 1300nits in HDR with thousands of zone, but when it come to bright bloat like fireworks details OLED still catch the details better overall.
zensushi
Moderator
Moderator
Upon reading, found out that 2m-long VESA-certified DP80 DisplayPort cables are hard to come by.
Had to place an order from Amazon US for one. 😔
