vee4044
- Mar 7, 2007
Depends on how you ask also.you try ask 10x stall hawkers.
i think only 1x you will return the change.
usually there is no change provided.
Wow! So if your cai png is $4. You can give $250 vouchers and they pay back $246 in cash? Can SIC the stall?the hawkers near my place give change. what's even better is they allow me to cash out everything if the vouchers are expiring soon. really nice people
Imagine there is some peoples who keep cdc voucher and forget to use.
Not that they don't really need support just that they love to keep the voucher and forget there is deadline.
I believe there is some kind.
You know everyday you want to buy something. You need to spend cashs. Everyone know it.
But cdc voucher is like once awhile have. You never know.![]()
I will say please keep the change.Food cost $6.50. you used $2, $5 cdc vouchers. Should stall return you $0.50?
I can tell you unless you friend with stall staff, he will give u back the change. Dun expect every stall to entertain u
Any Voucher use to purchase No change will Return.... Singapoo Practiced.
But My place Cai Png stall do give back change leh...![]()
You must stay at Low Ses estate
then they do.... I think So. My place many uncle / Aunties order only One vege One Tou Fo and Rice.
If you directly ask will they give change, maybe they scared you working for NEA/newspaper, want to test them to see they got give loophole, so they sure say no.
If order leow and say you left with x dollar CDC, confirm with them if you use the CDC, they will give you change hor, then they see you order leow, less likely to be spy. Then they more likely will entertain.
Also if kenna questioned, they got legit excuse that customer say only left the larger value vouchers, no indication they are trying to beat the system. (Like buy $0.80 kopi with $10 voucher).
usually i pay the differences with cash.
not the other way round.
Smart hawkers will know give back the excess credits in cash will ultimately attract more customers to the stall.The T&C already said excess cannot be refunded.
Gahment want you to use for food. Not to overpay, get refund, then go buy cigs and vodka.
Can not la...Can share where do you stay or where you term low ses estate is?
Can not la...![]()
I must protect my Old folks here... later long Q like Aston... How ?
Dun give back change Chances very High.... Some Hawker also greedy to keep the Change.Ask first.
Some give but some don't give change.
My place too small One sound U know Where... WP party no such power la.... their budget very tight too. After Election they take care their own pocket.... one.Asking for your estate not which stall did the CDC favor for you.
You think WP having rally at your place meh.
