Xiaomi Routers: Xiaomi BE10000/BE7000/BE6500 Pro/BE5000/BE3600, Xiaomi AX6000, Redmi AX6000, Redmi AX5400/Gaming, Xiaomi AX3200/AX3000, Xiaomi AX3000T
josesong
Hi I’m using wireless backhaul. Ok tried I turning off be5000 and it works. Seems like the wireless mesh is not working well.
josesong
Anyone able to help again on my Xiaomi BE6500 Pro router. I can’t seems to get it online again after 1 hour of trying ways. It’s not connected to mesh as my BE5000 is already turn off more than 1-2 days. Is it just doesn’t work with starhub? Thanks in advance.
Try the following to see if it helps.
1) Set up Google/Cloudflare DNS, 8.8.8.8 and 1.1.1.1
2) Enable IPv6
josesong
Hi morning. Have tired both DNS. Enable and disable IPV6. It didn’t work. Have verified ONT works too. Or it might be the BE6500pro failed? How do I check? If that’s the case what is the router to recommend for Starhub 5gbps plan. Thanks
Foetid
:cry: @xiaofan is ur best hope.
I wonder if your xiaomi is spoilt? Earlier i had this Intel AX200 NIC, worked in my lenovos for 5-6 years then suddenly laptop behave wierd, i thought finally amd 4800h has died/damaged later i realised its the wireless card causing the problems, worst? i bought a replacement also is same problem from carousell. Sigh, eventually i sold my laptop and get second handlaptop from carousell,plug in also same problem then i realised its the wireless card.
=> Story is do you have another spare router to try out? I think tons n tons of cheap be router in carousell, get some and test, later u can sell away the same way you bot it?
=> Can you terminate and use M1 instead? Previously for M1 i had to copy n paste my prior router MAC to my huawei router MAC.
i am glad i am using Huawei be 7 pro routers, no brainers like me, just plug to ONT and it auto mesh, good for no brainers.
i using M1 ONT-> HW BE 7 Pro->HW AX3 Pro.
Nothing need to be done, it just works.
josesong
yeah. thanks for the suggestion. after looking through the past few pages in this thread. Seems like HB710 is the one Xiaofan recommended to pair with starhub.
Let me do some research on the Huawei BE7 as well. Thanks for replying.
Meanwhile I will get a cheap router to test it out and use hotspot for the time being. Thanks
You can try with the Xiaomi BE5000 to see if it has the same issue or not.
Alert: Xiaomi AX3000T China version V2 (RD03V2) with V2.x FW has changed the chipset from MediaTek Filogic 820 (original version RD03) to a lower performance Qualcomm IPQ5018 chipset, and it is no longer supported by official OpenWRT version. Wireless performance is also degraded as per the tests from a few Chinese reviewers.
The global version selling in local official Xiaomi shops is RD23 which is still using MediaTek Filogic 820 chipset and it still supported by OpenWRT.
Reference:
https://openwrt.org/inbox/toh/xiaomi/ax3000t
Some Chinese websites will call RD03v2 as Xiaomi AX3000T HW Revision V3.
Local official Xiaomi Shops now have 4 types of WiFi 6 and dual band WiFi 7 routers.
1) Xiaomi AX3000T global version, WiFi 6, AX3000, S$62
https://www.mi.com/global/product/xiaomi-router-ax3000t/
2) Xiaomi BE3600 global version, dual band WiFi 7, BE3600, S$79
https://www.mi.com/global/product/xiaomi-router-be3600/
3) Xiaomi BE3600 Pro global version mesh, dual band WiFi 7, BE3600, nice form factor. Single pack at S$127, dual pack mesh bundle S$237. Take note the single pack contains the lower grade unit of the mesh bundle.
https://www.mi.com/global/product/xiaomi-mesh-system-be3600-pro/
4) Xiaomi AX3000NE global version mesh bundle, dual band WiFi 6, AX3000, nice form factor. Single pack S$69, dual pack S$129, triple pack S$165
https://www.mi.com/global/product/xiaomi-mesh-system-ax3000-ne/
EeeK
Hi, just did a factory reset on my Xiaomi BE3600 router and now my IP address is 192.168.31.X ranges.
My laptops are not able to ping each other. Which settings should I change for this?
koohansen
Laptops able to access the internet?
Check your Windows Firewall, if enabled Ping is blocked by default
Under File and Printer Sharing > Echo Request - ICMPv4-In
EeeK
ok can ping each other now.
my viewqwest ONT device is having IP 192.168.1.1, should I need to configure my Xiaomi BE3600 router to have the same network with 192.168.1.x?
PS: I got my Xiaomi BE3600 router from taobao last year, any global or openwrt firmware that I can flash?
koohansen
Your ONT and Router should not be on the same subnet, must be different to avoid conflicts.
For XiaoMi I have no experience with OpenWRT, but your model seems to be using Qualcomm IP53xx series, not supported if i'm not mistaken
Reference:
Updates: still not a good situation for Xiaomi. You will randomly get either the MT7981 version (V1 FW) or the weaker IPQ5018 version (V2 FW). Xiaomi tries to convinced the users that V2 FW version is better because of some new FW features.
Xiaomi FW download
https://www1.miwifi.com/wap_download.html
Xiaomi 全屋路由 BE3600 Pro 套装 稳定版​
版本1.0.56(2024年12月14日更新)
刷机教程 更新日志
下载
Xiaomi全屋路由BE3600 Pro 稳定版​
版本1.0.52(2024年12月14日更新)
刷机教程 更新日志
下载
Xiaomi路由器BE6500 稳定版​
版本1.0.43(2025年7月29日更新)
刷机教程 更新日志
下载
Xiaomi路由器BE5000 稳定版​
版本1.0.53(2024年5月11日更新)
刷机教程 更新日志
下载
Xiaomi路由器BE3600 稳定版​
版本1.0.31(2024年8月7日更新)
刷机教程 更新日志
下载
Xiaomi路由器BE3600 2.5G版 稳定版​
版本1.0.65(2024年8月7日更新)
刷机教程 更新日志
下载
Xiaomi路由器6500 Pro 稳定版​
版本1.1.26(2024年3月13日更新)
刷机教程 更新日志
下载
Xiaomi路由器AX3000T 稳定版 (MediaTek CPU)​
版本1.0.64(2023年12月22日更新)
刷机教程 更新日志
下载
Xiaomi路由器AX3000T新版 稳定版 (Qualcomm CPU)​
版本2.0.12(2025年4月8日更新)
刷机教程 更新日志
下载
Xiaomi万兆路由器稳定版​
版本1.1.56(2025年5月19日更新)
刷机教程 更新日志
下载
Xiaomi路由器7000
Xiaomi路由器7000
Xiaomi路由器7000 稳定版​
版本1.1.16(2024年2月27日更新)
刷机教程 更新日志
下载
greyhippo1
Hello @xiaofan I'm renovating my home so looking for some router/AP recos. House is big so Cat6 cables into 5 rooms (Ethernet - 1 each room) + Cat6 cables for 4 APs (Wifi - 2 per level). Other devices - TV/printer/security cameras/doorbell - overall very simple family usage, just need fast speed and good coverage :) Planning to change ISP (Singtel 1Gbps -> MyRepublic 3Gbps No Frills). Read that MyRepublic setup is ONT so landed in this forum as I'm looking to get China routers/APs directly from TB.
Setup is probably gonna be:
Main Router (Xiaomi BE7000 / TP-Link TL-7DR7260 BE7200)
Port 1 -> WAN in from ONT
Port 2 -> 2.5Gbps PoE switch for 4 APs - I saw Xiaomi / TP-Link China PoE APs that has a small form factor (power socket size) which is ideal but not sure if it works in SG? They are really cheap compared to getting Ubiquiti / Netgear / TP-Link SG round-form PoE APs that easily cost >$200. Prefer PoE APs as I don't need another electric point for each AP.
Port 3 -> 2.5Gbps switch for 5 Ethernet + 1 printer - just need all the laptops to be on the same network as the printer.
Port 4 -> TV
Port 5 (if TP-Link router) -> Security cameras / Doorbell
1. Does the above setup even make sense lmao
2. Leaning more towards TP-Link TL-7DR7260 BE7200 because it has 5 2.5Gbps ports vs. Xiaomi's 4. But setting up wise is it easy plug and play?
3. If the China PoE APs don't work in SG and I have to get Ubiquiti etc. APs will they work with China main router?
Port 4 -> TV
China POE APs will work. But you may not want to use Xiaomi BE7000 or TP-Link China TL-7DR7260 as the main router in that case, as they may not be compatible.
Out of the following two new popular solution from Xiaomi and Huawei, I tend to like Xiaomi a bit better since the main router has 512MB RAM.
TP-Link China, ZTE, H3C and Ruijie have also solutions for AC+AP.
You may want to check out this thread.
https://forums.hardwarezone.com.sg/threads/ac-ap-home-solution-from-china.7012259/
