How does this mini air-con works?
AvatarViper
It says can blow 16 degree cold air out but not using compressor or water wor.
https://detail.tmall.com/item.htm?a...357cc5aaa593c51dcab31d3c70"}&xxc=taobaoSearch
JohannSu1864
I go shopee bought a mini fan with a tank above. Can add ice water n blow out cold mist. Last night I use. Not bad I feel. Not very cold but helps in this kind of weather. Also must on normal fan la.
OutBreak
House will turn moldy or not?
sunsetbay
Moderator
Moderator
Using thermoelectric cooling plate right~? Previously razor got a product that able to cool the iphone as a attachment~ :s22:
kiatkiat
Oh, seem like it's using peltier chips for Aircon to lower the temperature. For those who are interested, can go and google "Thermoelectric cooling" .
But there is a reason why almost all aircon don't use this chip. the main reason will be it has a poor energy efficiency, meaning it will be using much more electric energy compare with a conventional type Aircon.
Orphan
Based on the device size, confirm using thermoelectric cooling.
Similar concept used in portable USB powered fridges.
Apparatus
Likely to use ceramic semiconductor technology for cooling. Such technology is being used in water dispenser for those without using a compressor with refrigerant
This is great for bedside/desktop cooling as no water/ice is being used
Apparatus
