30s-50s chitchat club
LingTan98
i never see my wife having a software to manage her rentals as a agent
but then maybe you have more than her
I called up to chat a little, it seems like it can help to sync up with maintenance work scheduling on the landlord's side, and reminders for tenants to submit proof of servicing.
lemonzil
Got quoted $130 - $180 just to fix that light… feeling a little ripped off. But likea no choice…
highsulphur
You have to determine the value to see if it's worth it
lemonzil
Isn't just change light blub? Or it a led fixture?
I think it’s Led. So replace the led is $130 but the electrician was saying some led lights can’t be removed. Need to change the entire light… so hence the $180.
I can’t even reach it to check what’s inside.
highsulphur
Yes for led you need to change the whole fixture. The whole light shouldn't cost more than $50 but it's not as straightforward as changing a light blub but still can be done with a ladder and some experience
lemonzil
Unfortunately, the ladder I have is not the normal height kind. So Yeap even at the highest step I still can’t reach.
singexpat
if led, sometimes it's the driver unit.
