Emperor_Hippo
- Aug 23, 2009
Start work 0800H.they start work at 8am
coming at 8am is the first test
u see them sashay in at 0800H instead. :x
Have to agree with you. They have very bad work ethic not pooryoung people nowadays have poor work ethics. everything is about themselves.
no wonder so many don't even have proper human friends.
Read HWZ Forum Rules!
Pretty much the hiring process for locals these daysMeans he just wanna chop chop curry pork
faster do and reject
Then ask for FT.![]()
Got google maps, grab, taxi, can use ChatGPT find location.Normally interviews should not be at 8am because interviewee is unfamiliar with the location and may need more time to travel there. But the reason given is valid so TS has to consider.
If TS needs the job, then TS should arrive there latest by 7.50am. If TS does not need the job, then TS can tell the company that he can only make it after 10am.
"unfamiliarity with location" may be an excuse when there was no smartphones and we are still using street directory to navigate, but its no longer an exc
as topic....
edit: interviewer is local. reason given he's travelling.
as topic....
jialat nowadays gen z want to invite interview also need to see the timing.
Haiz, might as well get jhk. interview on weekend also won’t complaint.
Willing to squeeze you in means interviewer also have to wake up early right… if not keen, interviewer can just push your interview down the line…as topic....
