Knife set.. any chef here?
sky00sky
Googled
Dick Premier Plus is
X50CrMoV15 steel alloy
The blade is made of the high quality X50CrMoV15 steel alloy. Each component of this steel has its own impressive features.
tbh not to shabby but by its HRC is 55-57 slightly lower compared to what the other mention.
Maybe chopping board issue?
DragonFire
Lmao, that really can destroy your knife
It survived, but under strong light you can see the edge rolled in places. I’d paid someone to waterstone away the factory grind prior and was heartbroken lol.
I got a case of XXXX beer in apology. Guy knew to do that or not get any more oyster sauce braised chicken outta my pot.
DragonFire
Carbon steel knife will be a beast to handle for a casual user as they will rust and also if the user is used to using blunt knife before, carbon steel knife in such a person hand used to using force to cut will likely make the person slice his finger.
My mum used to blunt knife all her life and came my place and tried to use my knifes which are super sharp, sliced her hand quite badly lotsa blood and from then onwards dun dare to touch my knifes again.
She probably cut through whatever she was cutting with unexpected ease. School of though says you are less likely to injure yourself with a sharp tool. On the other hand if you do injure yourself with a sharp tool, it will be a big problem.
I cut myself with an S30V blade two years ago. Let’s just say my fingertip has a different shape now. There was no pain, just an itch. 1/3 of the nail and nailbed came off.
lalalalalala
go get some damascus steel knife set.
they looks sic...
Iirc damascus is expensive and a pain to maintain. Need to dry it after every use or will rust.
Imo if not professional any knife will do. Just make sure to sharpen and not let it blunt. Modern day tech already makes your ntuc and daiso knife 80 to 90% there. More expensive have diminishing returns. You're alot better off buying a knife sharpener and a honing rod. Both cost less than $10 and can probably last afew lifetimes
The $200+ and above knives are more for professional level if u use everyday. Always remember your cai png shop doesn't use a $200 shun to slice the 100 kg of veggie they go through everyday
hardindex
go market ask the pork seller wherre he brought his knife, just get the same one 🐔
DragonFire
Most are carbon steel. Not for newbies. Maintenance after business day. Carbon steel holds the finest edge. Only problem is it will turn brown overnight if not oiled.
Getting a blade for a SO who is a chef or a hobby chef?
You gotta know what style they like to use.
I'm no chef, but I do like my blades. My main kit is from Shun. They be a 6 inch santoku and a traditional cleaver.
The santoku is smaller than the usual 7". The cleaver covers where it is too small for the job.
Kai Shun is not a cheap line, but is readily available. There are made from VG Max steel which holds a great edge whilst being relatively easy to sharpen,
Studying culinary. Using sharp knife really makes your cutting better.
rrr2015
then u should let your school recommend u a knife set. without knowing type of culinary u study, doubt anyone here can recommend u a suitable set
testerjp
Very hard metal, after it's blunt, harder to sharpen.
Softer or too thin, gets blunt easily but easier to sharpen.
Actually, the real way to own a good set of knives is to first get a good knife sharpener. :(
sky00sky
actually no need per say good la
just decent and can own self learn how to sharpen
1000/3000 + sink top holder
day to day good enough
TS , the usual basic one should be the Mercer usually u see people like to recommend but u already using the germany one which seems like same steel
i gifted a family member whom likes to cook a lot a Fujitora (tojiro)
but see what you need and also budget also. some places cannot use wooden handles , then also the blade type ,
sky00sky
how about wmf knife set?
1 cent money 1 cent goods.
wmf is just a brand they have such a huge range and those usually we can see available mostly is just entry.
but home use not much expectation anything works.
if hardworking to sharpen....even ikea 365+
