xonix
- Mar 24, 2001
If you sign up for 10gbps plan from M1, you can grab the BT10 bundle. That has 2 x 10gbps ports on each unit. You can continue to use the ax88u on any other data point in the house for additional wifi coverage. You will need to purchase a 10gbe pcie card for your PC to maximise the higher broadband speed.Replacing my home routers - 3br hdb bro
current set up is 1 x Asus ax 1800 in db box (wifi turned off) - connected via ethernet to study room computer and another connection to living room for asus ax88 acting as AP for wifi around the house. WiFi is not that great in master room since router is nearer to kitchen than rooms which is fine, I still get 2-3 bars.
I am thinking of going wifi7 to replace my aging routers. I tried googling and most routers seem to feature only 1 10g port.
what should I get so that my living room router can support 10g for wifi throughout the house and my study room pc can also receive 10g through its ethernet port?
I haven’t signed up for my 10g though but likely will recon thru m1.
