China Tablets to recommend
xonix
Tough decision to make... :unsure:
Obviously you will only get updates with Redmi K Pad :(
Xiaomi Redmi K PadiPlay 70 mini Ultra
SIZE205.1 x 132 x 6.5 mm208.2 x 129.6 x 7.9mm
WEIGHT326 g335 g
DISPLAY8.8 IPS8.8 IPS
ANDROID1514
SOCDimensity 9400+SD 7+ gen 3
SD SLOTNoYes
MEMORY12 / 256 gb12 / 256 gb
SPEAKERSDualDual
WIFI76
USB3.2 ( Display out ? )3.1 ( Display Out supported )
BATTERY7500 mah7300 mAh
PRICEapprox S$550approx S$370
halocast
Flagship soc versus mid-range soc, updates on redmi.
Price seems to match the specs,
Would prefer redmi.
Parka
Weak point of Alldocube iPlay mini Ultra is the audio. So will depend on how good audio is with the Redmi and whether you are willing to pay for it
xonix
Would prefer redmi.
I actually prefer the alldocube UI over hyper os and could live with it had they launched with Android 15. Was hoping didn't need to spend so much on tablet that I will only be using for occasional video editing & media consumption.
From what I heard in youtube reviews, while it's not great but usable and acceptable for the price.
halocast
Ya too bad they dun do updates pretty much :o
vofzxy
do these brands like alldocube , Redmi, iplay still make windows tablet?
or there is no demand for windows tablet outside the Surface?
i just need one simple easy-to-use on the go, offce , internet, watch drama.....
froztheart
Windows literally only left with Surface/Mini PC.
Nowadays don't even see such devices around.
dreamcast18
not common in SG, but u can find them elsewhere:
https://www.amazon.com/CHUWI-Hi10-X1-Windows-Cameras/dp/B0DMT7XHF3/
https://www.amazon.com/AWOW-Windows-Touchscreen-Processor-Bluetooth/dp/B0DQ4NVYFF/
runs Win11 Pro
https://www.amazon.com/Fusion5-10-1-Windows-Professional-Tablet/dp/B0DSWJL6K5
14" 16GB
https://www.amazon.com/TPV-RenoPad-Quad-Core-Touchscreen-Gray-Upgraded/dp/B0D9N7LJPB/
not sure how this off-brand tablets quality are...I personally would stick with Asus or MSFT for Windows Tablet.
If XM makes a Poco/Redmi Win11 tablet..would jump on it.
dreamcast18
tough
for gaming, suggest to consider ipad
refurbished ipad 10 $359
https://www.apple.com/sg/shop/refurbished
Gone liao :s13:
TBH; Ipads are really good value. This one is USD279 which is SGD357 BRAND NEW from Amazon.
https://www.amazon.com/dp/B0DZ77D5HL
if the apple magic keyboard was not so $$$, would have gotten this over the PocoPad.
dreamcast18
There are alternative keyboard cases available, e.g. Logitech
yep i know..but i prefer factory keyboard for seamless integration. The apple one is really a crazy markup..i've seen cheap ones on SHEIN but don't trust. Plus ipad better updates than any android tablets..even tho Poco Pad has been getting monthly updates..amazingly.
froztheart
Well, pain one time nia, can use for quite a while so it's a good investment.
I went with Logitech so it's cheaper. :s13:
twinbaby
1 . I'm currently using a xiaomi tablet which he Xiaomi Pad 7 pro. The set is 12 + 256 GB and brought from China.
2. Currently I have noticed a few different from the global version.
A) even if I install WhatsApp on it, the notification will be delayed by a few hours before I get a notification.
B) the AI does not integrate with Gemini, it is a Xiaomi standalone HyperOS AI. It is always expecting me to speak in Mandarin.
C) initially the Google map doesn't work at all, I actually have to turn on the some settings that actually improve the map feature, asuccessfully it turn on successfully.
D) They are using Getapps, sometimes the application installation can actually override my Google Play installation. This may not be actually a good thing because, some of the application actually asked me to use the global version, e.g Wechat when making payment.
e) if I want to contact their customer service this is okay however I need to call +86-950817, even my international roaming actually does not support this.
F) I'm also currently looking at, NFC feature, however the phone seems to be missing the feature.
