helloicanseeu
- Jul 12, 2009
what plan is that???I’m on 10mbps now
10gb stuff is still quite expensive, not worth the investment for now ....if you're not on wifi6 and above... then you don't need anything more than 1gbps... wifi6 can reach 9.6gbps maximum speed... wifi7 even more ridiculous... but if you're not on those technology levels... then no... your limit is 1gbps....
I think all ISP offer min 3Gbps now
Not only router, most desktop motherboard's Ethernet port is still 1gbps, so to use the newer service will need to buy an explicit PCI-E 10gbps network adapter.A lot of people don’t realize that when they subscribe to broadband plans above 1 Gbps, any speed beyond 1 Gbps is unused if their router doesn’t support higher input speeds. Most routers that come with standard subscriptions only support up to 1 Gbps on the input port, unless you opt for higher-priced plans that include routers capable of higher input speeds (e.g., 2.5 Gbps).
However, many people don’t mind because 1 Gbps is already fast enough to notice any difference, and they may mistakenly believe they’re benefiting from the higher bandwidth (e.g., 3 Gbps), when in reality they’re still limited to 1 Gbps by their router, a case of placebo effect.
Using SIM cardwhat plan is that???
Even 100mbps also don’t need lahA lot of people don’t realize that when they subscribe to broadband plans above 1 Gbps, any speed beyond 1 Gbps is unused if their router doesn’t support higher input speeds. Most routers that come with standard subscriptions only support up to 1 Gbps on the input port, unless you opt for higher-priced plans that include routers capable of higher input speeds (e.g., 2.5 Gbps).
nowadays most MB support 2.5gbps ba, older ones max 1gbpsNot only router, most desktop motherboard's Ethernet port is still 1gbps, so to use the newer service will need to buy an explicit PCI-E 10gbps network adapter.
