China Tablets to recommend
froztheart
1 . I'm currently using a xiaomi tablet which he Xiaomi Pad 7 pro. The set is 12 + 256 GB and brought from China.
2. Currently I have noticed a few different from the global version.
A) even if I install WhatsApp on it, the notification will be delayed by a few hours before I get a notification.
B) the AI does not integrate with Gemini, it is a Xiaomi standalone HyperOS AI. It is always expecting me to speak in Mandarin.
C) initially the Google map doesn't work at all, I actually have to turn on the some settings that actually improve the map feature, asuccessfully it turn on successfully.
D) They are using Getapps, sometimes the application installation can actually override my Google Play installation. This may not be actually a good thing because, some of the application actually asked me to use the global version, e.g Wechat when making payment.
e) if I want to contact their customer service this is okay however I need to call +86-950817, even my international roaming actually does not support this.
F) I'm also currently looking at, NFC feature, however the phone seems to be missing the feature.
Yes, WhatsApp delay is pretty common issue, have you check your battery saving/restriction settings
Yup, no integration with Gemini.
It's known for CN set to have some issues with GPS IIRC.
You can disable "GetApps" by revoking it's rights in the setting IIRC.
Try contacting SG's CS then, but doubt they support China set.
Which phones that you are looking at has NFC missing? I believe nowadays almost all/most should have NFC capabilities
twinbaby
Xiaomi pad 7 pro has no NFC, anyone confirm
dreamcast18
chari-men
Dorkable
Alldocube launching their Ultra Pad on AliExpress come 10 Sep 2025. It is basically a bigger iPlay 70 Mini Ultra.
- Android 15
- same Snapdragon 7+ Gen 3 SoC
- 12Gb ram 256Gb storage with Microsd Card support
- 13" 2.8k 144Hz IPS display 700nits
- 15,000 mAh battery with 33w fast charging
- USB 3.1 Gen 2 Type-C port
- Wifi only Global version
GhostZM
OnePlus Pad 3 base model going for $485+ after vouchers for 9.9 sales on Shopee now..I think it's a fantastic price
CheerS!!!;)
Teo Ming Ern
Can flash to Global ROM?
kottty
