Car falls into sinkhole at Tanjong Katong Road South; one person taken to hospital
Katong sinkhole incident - Would you jump down the sinkhole to help the lady if there is no foreign
  • Yes of course, must try to save even if I dun know how dangerous the sinkhole is
    Votes: 24 19.4%
  • No way, I dun know how danger the sinkhole will be
    Votes: 46 37.1%
  • No BUT i will call police
    Votes: 79 63.7%
  • Total voters
    124
*Sisyphus*
My guess is that the tunnelling access shaft for PUB work (in red) caused some soil movement, which ruptured the water mains pipe (in blue). The gushing water from the ruptured pipe then displaced a large amount of soil, accelerated the creation of the sinkhole. The freshly repaved road was probably just a temporary but ineffective patch over an underlying issue that hadn’t been properly identified and fixed. I also won’t be suprised that there were telltale signs like increased water/soil ingress into the access shaft (in red) recently due to the ruptured water mains but this wasn’t seriously taken as a warning sign
Get cheaper better faster workers/engineers who don't care sinkapore sinks more important!!
week3nd
Why should there be hole? I thought all the road should be concreted filled up... then worse case only road got cracked only... i mean is something wrong somewhere for this case?
There is a burst pipe somewhere and the soil underground is washed away into the pipe or somewhere else, which creates a hole underground
Potato_Wedges
https://www.channelnewsasia.com/sin...d-south-road-collapse-one-amber-condo-5260056
Medicated Oil
High Honorary Member
To be honest im v afraid now. You see punggol so many roadworks….actually most of SG
They are doing so many roadworks.
And if they are lucky enough to get a inexperienced foreman to instruct the clueless workers, then I dun need to say further.
*Sisyphus*
Wow the pipes burst the day before and Lta nvr check still let people drive on that stretch of road?
U expect the jlb lta civil serpents to work??? Pma/pmds they simple job they also don't bother catch...this kind so big job some more after office hours u expect them to work????
Iamdone
The road has darker patch, means newly patched and/or some construction undergone below it recently. Yet sink happened.. really sinkies land
