LG 2024 TV discussion thread
Nakedtoes
Can I check... Currently. Mine LG 65CX is mounted on the old LG TV mount given free for mine 55C7 many years ago.. The mount came from LG swivel type.. Can I still use the same mount on mine coming 77B4? I see that the weight of the 77B4 is 23kg and mine current 65CX is 24kg.
Current using this type of mount.. LG only 1 type/ model?
https://i.supaimg.com/bac36812-772a-4cc4-8f86-4c26e5043222.jpg
eS.KuKu
those carouselll seller selling 65inch G5 at 3599 legit anot? say got invoice and all
kappak
the mount model is olw480b(support up to 49KG)
it support 300x 200 so can use on 77B4
mine also using same mount
from 65CX to 65G4(didnt use G4 flush mount coz i mount on top of another 65")
Nakedtoes
K.. Think mine is model 240 instead of 480..mine is from 2017 LG oled... I see that it can support up to 40kg TV.. The 77inch is 23kg.. So I am using bavk the mount.. Cause dun want to drill new holes on the wall.. Anything I should take note? TV mount can last right?
Nakedtoes
Can check now when u pause youtube.. No more firework Screensaver come out?
maxyorkie
Went with C4 55” at BD @$2049 with $100 evoucher and free XO3 portable bluetooth speaker. knocked off another $40 using citibank cc.
