GotBetrayed
- Mar 27, 2013
ok 77B4 no stock liao.
bro do u tink still gt G4 77 in the market?ok 77B4 no stock liao.
Idk leh. Back then I thought I posted, should be around 6k during clearance. Maybe all clear Liao?bro do u tink still gt G4 77 in the market?
I see. i nv rly go ask ask. tot u would know from ur networkIdk leh. Back then I thought I posted, should be around 6k during clearance. Maybe all clear Liao?
I aiming 77G5/83G5.
four only in a square. even single oneThey got so many oled TV of cos la.
Just ordered a set 3498 @BDok 77B4 no stock liao.
Nice good price. I just hope we can see price drop in sg for 77/83G5.Just ordered a set 3498 @BD
https://i.supaimg.com/bac36812-772a-4cc4-8f86-4c26e5043222.jpgthe mount model is olw480b(support up to 49KG)Can I check... Currently. Mine LG 65CX is mounted on the old LG TV mount given free for mine 55C7 many years ago.. The mount came from LG swivel type.. Can I still use the same mount on mine coming 77B4? I see that the weight of the 77B4 is 23kg and mine current 65CX is 24kg.
Current using this type of mount.. LG only 1 type/ model?
K.. Think mine is model 240 instead of 480..mine is from 2017 LG oled... I see that it can support up to 40kg TV.. The 77inch is 23kg.. So I am using bavk the mount.. Cause dun want to drill new holes on the wall.. Anything I should take note? TV mount can last right?the mount model is olw480b(support up to 49KG)
it support 300x 200 so can use on 77B4
mine also using same mount
from 65CX to 65G4(didnt use G4 flush mount coz i mount on top of another 65")
Got mine 65” at $2,799 at BD.Hi guys, Anyone knows where is the best deal for g4 now?
Nice catch bro! which outlet? can intro your sales?Got mine 65” at $2,799 at BD.
Yes bro can pass contact? And which outlet?Nice catch bro! which outlet? can intro your sales?![]()
