Need to wait for 12 mths
Previously after I waited for 11 mths, they announced they were going to slash the interest rate, hard...
I've zerolised the acct for long time now.unless you already can meet the minimum relationship amount. just keep this account running with 1 dollar. interest rate will still go back up after some time.
i only know you get charge if fall below the TRB. last time i just keep some small amount without withdrawl. untiil i realised the interest counter was to the max when they revise the interest upwards. the counter is still valid all these year. you can call the cso to confirm what the minimum amount to keep.I've zerolised the acct for long time now.
What does the $1 do? Will it get deducted as service fee each month for below TRB? Does it help to increase counter each month even if does not meet the TRB? If just the keep acct active $0 will be fine according to CSO.
That’s a smart move. Ya. The counter will keep increasing when you receive some interest and din touch the fund and the counter will be at max. All good if you hold the TRB or a citigold and above customer.i only know you get charge if fall below the TRB. last time i just keep some small amount without withdrawl. untiil i realised the interest counter was to the max when they revise the interest upwards. the counter is still valid all these year. you can call the cso to confirm what the minimum amount to keep.
If need to, open a Citi Interest Booster a/c which has base interest 1.5% p.a. (with additional categories of bonus interest with some criteria). Put TRB $15k in Interest Booster a/c while you figure out your maxigain a/c, transfer the $15k over to Maxigain if the counters are ok & give higher than 1.5%.I've zerolised the acct for long time now.
very smart moveIf need to, open a Citi Interest Booster a/c which has base interest 1.5% p.a. (with additional categories of bonus interest with some criteria). Put TRB $15k in Interest Booster a/c while you figure out your maxigain a/c, transfer the $15k over to Maxigain if the counters are ok & give higher than 1.5%.
https://www1.citibank.com.sg/wealth...?icid=SGENCBGBAMITLCitiInterestBoosterAccount
I applied online and got rejectedIf need to, open a Citi Interest Booster a/c which has base interest 1.5% p.a. (with additional categories of bonus interest with some criteria). Put TRB $15k in Interest Booster a/c while you figure out your maxigain a/c, transfer the $15k over to Maxigain if the counters are ok & give higher than 1.5%.
Why rejected siaI applied online and got rejected
What is the interest rate % that can be achieved?this one still going strong. guess have to shift funds here already
3.01% may be revised later as US Fed Reserve has just cut the rate.https://www.citibank.com.sg/content...gs-account/citi-maxigain-savings-account.html
3.01% for 100k. but it will take 12 months to reach.
anything to do each month? like adding $xxx? and any minimum amount to keep get increase each month?https://www.citibank.com.sg/content...gs-account/citi-maxigain-savings-account.html
No need to add..just maintain 15k until u reached the 13th mthanything to do each month? like adding $xxx? and any minimum amount to keep get increase each month?
great, thank you!No need to add..just maintain 15k until u reached the 13th mth
