Oppo Find X8 Series
Shadow79
Guys checking if there is any rumours of upcoming Oppo update to add number badges for app like WhatsApp Business. Just got the global ROM version of the Pro and quite surprised number badges for WhatsApp Business is not supported. Currently using the OnePlus Launcher workaround but seems like so weird.
vaxvms
I think one issue with oppo china rom is only the max limit of autostart 5 or 6 apps rite if not wrong...
max only 5 for oppo x6pro
x8 shoul be ard there as china rom limit launch for better battery performance i guess
LordDo0m
Does not have Quick share but have something similar call Oppo Share.
Google home, no problem. I do have google home on my OFX8U.
Dunno wad was TS issue on no minus one google home.
The real real breaker to me is no esim (out of the box) But again, there is a solution for it.
Hi, can you share the workaround for esim please? TIA
Skyy
the workaround is to sign up for a service like esim.me then u get a physical sim which functions like an esim. Depends on your use case. for me i use esim like eskimo for extra data during travelling so getting esim.me doesn't feel very value for money, it ain't cheap. just google "esim.me alternatives" and u can find other brands with varying prices.
LordDo0m
Thanks! Any advice to pair Samsung watch to the phone?
Skyy
u mean u tried and it doesn't work? i'm using a samsung watch and it works fine with my FX8P. I changed from a Samsung ultra phone to FX8P, didn't even need to wipe my Samsung Watch. Just need to install the Samsung Health app and Galaxy Wear app from the Play Store to the phone, pair then that's it.
By default u won't get ECG and Blood Pressure unless you install a modded version of Samsung Health Monitor which i did but this process a bit complicated.
chari-men
China rom need to tweak some stuff to pair with wearos watches...
progene
My previous china phone ( Oppo Find X6 Pro) able to pair with Samsung Watch 5.
Using the wearos by google (china), Samsung health in the oppo app market.
Bu the time to tweet, not worth it. Cos Samsung watch need to charge daily. So now using Huawei watch, charges once every 12-14 days...
LordDo0m
Watch otw so asking first 😅
So just dl WearOS and Samsung Health from Oppo App Market should suffice?
Skyy
wow you so brave, bought the watch before confirming that it can be used on the china phone. what if cannot use how?
Skyy
I might be WOLS but I updated to the latest SW and realised there is custom battery charging limits, just like One UI7 so I'm no longer stuck with max 80% or 100%. A lot of other brands all have this setting, so it's good that Oppo finally caught up.
And I'm not 100% sure about this, but I think there's a new setting where the battery % remaining can now be outside of the battery icon, which makes the % bigger and more visible.
[Edit] Most likely this setting is already there, i saw it in my much older Oppo phone.
Cyborg
Pondering whether to buy this X8 Pro or just wait till Oct/Nov for the launch of X9 Pro?
napster79
X9 Pro is most probably going to cost around $1.5k at launch, you think you wanna pay the difference for a newer model? 😅
Cyborg
Yes, I know price will sure to be high during launch, but also must consider what are the specifications provided for that high price, then can consider.
Although I have viewed some of the leak specifications on X9 Pro via YT, I would not take it as true for now.
napster79
IMO, nowadays phone technology has already reached the peak and bottle-necked, I dont foresee any big improvement is going to happen.
Most likely is slightly better camera, ultra-sonic fingerprint and bigger battery, which don't seem tempting for most people.
Of cos, if cost is not a concern, its always better to get the newest model. :giggle:
Cyborg
Yup, do agree with your opinions.
Probably Oppo X8 Pro at $900+ may be a good buy.
