Anyone stopped dumping toilet paper into the toilet bowl??
Mecisteus
It depends on the amount of toilet paper.
Just little is fine. Won't clog.
Been throwing inside for years.
And please use bidet and soap.
Mystyque
Only in overseas la. I think for countries like jpn or tw, their system cannot handle big load of toilet paper
Is a problem in older TW buildings but since about 10 years back, TW government had been educating ppl that plumbing had been upgraded and/or all toilet paper qualified to be sold in Taiwan disintegrate rapidly in water so it is no longer an issue?
sacredrays
wipes and toilet paper same thing? i heard some ppl use wet wipes, that one higher chance to clog
tessss
toilet paper ok. its meant to breakdown easily upon soaking in water.
but not normal tissue or kitchen tissue
eyz
use bidet still have to wipe first.
i used to notice the poo stain underneath the toilet bowl cover, and was puzzled how come the stain can get to there.
it was then i realized my wife has been spraying right after the dump, with those stuff still sticking onto the hole. so you can imagine, when the jet water spray at the hole with the dump, the dump just fly all over the place in the toilet bowl.
advice: still have to wipe before water spray.
winningeleven
Toilet paper can dissolve in the water . That why it is safe to dump into it . But not those packet tissues and wet wipe . Some people throw that into it and that why it might clogged.
As many said . Should install bidet. Once u used it. U will never want to use those public toilet without bidets unless really no choice.
Jian19
Can flash first
Than use spray wash pigu
Than wipe , u will only use less than 1/10 of wad u using now
AnTzX_
i try not to take a dump outside... at hm i use bidet... :o
testerjp
TS wife from China or some third world countries and giving ill advise to psycho him is it.
The opening of the drain under the bowl is almost palm size so big leh. It will only choke if you throw something like a towel in. 10 ply tissues also no problem.
Even the opening for the bowl drain I estimate is about 2 in wide.
If the main drain can choke, it's the main drain choke contributed by all the neighbours living in the same column.
The openings can get smaller if the users pour oil in which solidify and choke the points. Then it's a town council hdb issue.
