WiFi 7 Device SpeedTest and WiFi 7 adapters
Amazon eero Max 7 MLO vs non-MLO Wifi speed.
The best speed for Intel BE200 is quite impressive, either on the 6GHz band, or 5GHz+6GHz MLO. This is especially true for the upload speed.
On the other hand, if you watch the full video, you can see the speeds vary by quite a bit.
1) 6GHz band.
2) 5GHz+6GHz MLO
ZTE BE7200 PRO+ WiFi 7 performance, main 2.4GHz+5GHz MLO SSID
Acer Swift Go 14 laptop 2024 model, Intel BE200 based Intel Killer BE1750 WiFi 7 adapter
3m distance
Bash:
PS C:\work\networking\ookla-speedtest-1.2.0-win64> .\speedtest.exe -s 13623
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.79 ms   (jitter: 0.32ms, low: 3.45ms, high: 4.19ms)
    Download:  1427.51 Mbps (data used: 2.4 GB)
                 12.29 ms   (jitter: 8.22ms, low: 3.87ms, high: 236.93ms)
      Upload:   989.87 Mbps (data used: 1.3 GB)
                 11.94 ms   (jitter: 5.16ms, low: 3.65ms, high: 35.93ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/bd59f510-4824-4a60-8f08-304ab8b133fa
1m distance
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     4.79 ms   (jitter: 0.46ms, low: 4.63ms, high: 5.54ms)
    Download:  1935.10 Mbps (data used: 3.4 GB)
                 15.97 ms   (jitter: 7.88ms, low: 4.74ms, high: 237.66ms)
      Upload:  1343.83 Mbps (data used: 1.6 GB)
                  8.48 ms   (jitter: 2.49ms, low: 4.52ms, high: 16.78ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/a87fe6ed-5707-4c28-8831-9f4d0b5162e1
Usually I like to use 160MHz on 5GHz band when carrying out speedtest as that usually yields higher speed. But many people may not be able to get 160MHz channel Bandwidth working well due to interferences from the neighbours.
Wireless speedtest for WiFi 7 routers with 5GHz band, 80MHz vs 160MHz Channel Bandwidth.
1. Test condition:
All wireless routers-- 5GHz band, 80MHz channel bandwidth.
Acer Swift Go 14 2024 model, Intel BE200 WiFi 7 chipset, 3m distance to the router.
The Asus RT-AX86U is always present (since the other family members need to use wireless, using CH149 and 80MHz channel bandwidth) and it is 1m away from the other routers (one at a time, using CH60 on 5GHz band).
Reference speed for RT-AX86U (WiFi 6, 1024QAM), 1201Mbps PHY Speed.
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.10 ms   (jitter: 0.78ms, low: 2.44ms, high: 3.51ms)
    Download:   843.45 Mbps (data used: 1.5 GB)
                 17.26 ms   (jitter: 5.91ms, low: 5.02ms, high: 31.49ms)
      Upload:   500.67 Mbps (data used: 296.7 MB)
                 21.37 ms   (jitter: 16.37ms, low: 4.60ms, high: 153.13ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/d964d050-49dc-4cb1-a88b-bd742f102b4a
2. Asus TUF-BE6500 dual band WiFi 7, Asus Stock FW, CH60, 5GHz band, AP mode with 2.5Gbe WAN connection, behind main OpenWRT router.
1) 160 MHz channel bandwidth on 5GHz band. 2.4GHz+5GHz MLO enabled. PHY Speed 2882 Mbps.
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.47 ms   (jitter: 0.05ms, low: 3.44ms, high: 3.55ms)
    Download:  1399.18 Mbps (data used: 1.8 GB)
                  9.30 ms   (jitter: 6.58ms, low: 3.13ms, high: 238.35ms)
      Upload:   978.15 Mbps (data used: 775.5 MB)
                 11.53 ms   (jitter: 5.30ms, low: 3.60ms, high: 39.81ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/af3f0401-873a-430a-9381-56191c2662d7
2) 80 MHz channel bandwidth on 5GHz band. 2.4GHz+5GHz MLO enabled.
But MLO is no longer working in this case, fall back to 5GHz WiFi 6 connection. PHY Speed 1441 Mbps.
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.78 ms   (jitter: 0.73ms, low: 3.02ms, high: 4.34ms)
    Download:   854.87 Mbps (data used: 1.5 GB)
                 18.70 ms   (jitter: 7.09ms, low: 3.71ms, high: 45.69ms)
      Upload:   668.81 Mbps (data used: 1.1 GB)
                 18.33 ms   (jitter: 10.09ms, low: 3.54ms, high: 117.16ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/dc11bfd0-9d01-44b6-8d90-0814ebfd8fcc
3. Xiaomi BE5000 dual band WiFi 7, Xiaomi Stock FW, CH60, 5GHz band
2.5Gbe WAN Connection (Double NAT behind main OpenWRT router)
1) 160/80/40/20 MHz channel bandwidth on 5GHz band. MLO disabled. PHY Speed 2882 Mbps (160Mhz)
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.61 ms   (jitter: 0.35ms, low: 3.45ms, high: 3.93ms)
    Download:  1511.63 Mbps (data used: 2.7 GB)
                 10.46 ms   (jitter: 3.76ms, low: 4.72ms, high: 34.24ms)
      Upload:  1197.21 Mbps (data used: 1.1 GB)
                  9.15 ms   (jitter: 4.70ms, low: 3.16ms, high: 48.45ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/c95ab1e8-e697-459d-ac5b-688f9fb59a3d
2) 80 MHz channel bandwidth. MLO disabled. PHY Speed 1441 Mbps.
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.98 ms   (jitter: 0.20ms, low: 3.66ms, high: 4.16ms)
    Download:   983.25 Mbps (data used: 960.8 MB)
                 18.16 ms   (jitter: 5.76ms, low: 5.65ms, high: 35.56ms)
      Upload:   832.43 Mbps (data used: 1.2 GB)
                 14.87 ms   (jitter: 6.45ms, low: 2.75ms, high: 63.36ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/4e606b54-252b-4118-8533-f8bbce2dffe5
4. ZTE BE7200 dual band WiFi 7, ZTE Stock FW, CH60, 5GHz band
2.5Gbe WAN connection, Double NAT behind main OpenWRT router.
1) 160/80/40/20 MHz channel bandwidth. main 2.4GHz+5GHz MLO SSID, PHY Speed 2882 Mbps (160MHz on 5GHz band and 20MHz on 2.4GHz band)
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.57 ms   (jitter: 0.15ms, low: 3.37ms, high: 3.87ms)
    Download:  1271.14 Mbps (data used: 2.2 GB)
                  9.93 ms   (jitter: 3.84ms, low: 3.90ms, high: 50.30ms)
      Upload:   684.88 Mbps (data used: 429.4 MB)
                 13.05 ms   (jitter: 3.60ms, low: 7.04ms, high: 35.28ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/3092828d-4772-43cb-adc6-5b07047a2ace
2) 5GHz guest network, 160/80/40/20 MHz channel bandwidth. PHY Speed 2882 Mbps (160MHz channel bandwidth).
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.97 ms   (jitter: 0.22ms, low: 3.80ms, high: 4.13ms)
    Download:  1213.76 Mbps (data used: 2.2 GB)
                 13.67 ms   (jitter: 5.42ms, low: 4.11ms, high: 42.35ms)
      Upload:   843.63 Mbps (data used: 920.6 MB)
                 13.30 ms   (jitter: 6.59ms, low: 4.30ms, high: 34.44ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/bee2615f-6688-4f54-b311-4aaa88b5dfca
3) 80 MHz channel bandwidth, main 2.4GHz+5GHz MLO SSID, PHY Speed 2882 Mbps (80MHz on 5GHz band and 20MHz on 2.4GHz band).
MLO is still working but speed drops significantly.
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.66 ms   (jitter: 0.33ms, low: 3.51ms, high: 4.36ms)
    Download:   704.94 Mbps (data used: 913.3 MB)
                 17.85 ms   (jitter: 7.76ms, low: 5.88ms, high: 42.28ms)
      Upload:   381.26 Mbps (data used: 648.0 MB)
                 35.79 ms   (jitter: 16.80ms, low: 4.35ms, high: 157.12ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/1b4071a3-b06c-4bfe-ad1f-f5a90578122d
4) 5GHz guest network, 80 MHz channel bandwidth. PHY Speed 1441 Mbps. Same that speed drops significantly.
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.09 ms   (jitter: 0.16ms, low: 2.83ms, high: 3.19ms)
    Download:   757.63 Mbps (data used: 1.3 GB)
                 19.32 ms   (jitter: 8.90ms, low: 3.67ms, high: 73.62ms)
      Upload:   284.71 Mbps (data used: 504.8 MB)
                 58.76 ms   (jitter: 21.89ms, low: 3.85ms, high: 175.21ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/d1c24e29-9141-43e6-b4f3-73a0aed67a5f
5. TP-Link Archer BE805 triband WiFi 7 router, TP-Link stock FW, CH60, 5G band
10Gbe WAN connection, Double NAT behind main OpenWRT router.
1) 5GHz band, 160/80/40/20 MHz channel bandwidth. PHY Speed 2882 Mbps (160MHz)
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.57 ms   (jitter: 0.16ms, low: 3.49ms, high: 4.09ms)
    Download:  1580.65 Mbps (data used: 2.8 GB)
                 14.74 ms   (jitter: 6.06ms, low: 3.17ms, high: 34.01ms)
      Upload:   945.10 Mbps (data used: 1.7 GB)
                 12.50 ms   (jitter: 6.78ms, low: 2.66ms, high: 54.70ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/9870cafd-9c38-47c5-b855-b6cfb8836c01
2) 5GHz band, 80/40/20 MHz channel bandwidth. PHY Speed 1441 Mbps (80MHz).
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.55 ms   (jitter: 0.22ms, low: 3.31ms, high: 3.80ms)
    Download:   888.70 Mbps (data used: 930.2 MB)
                 16.92 ms   (jitter: 7.72ms, low: 3.22ms, high: 38.28ms)
      Upload:   711.89 Mbps (data used: 1.0 GB)
                 15.85 ms   (jitter: 8.12ms, low: 2.85ms, high: 88.89ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/d3d91eb5-6802-457b-ab07-eaecfd102535
6. TP-Link Archer BE805 triband WiFi 7 router, TP-Link stock FW, CH85, 6GHz band
1) 6GHz band, 320/160/80/40/20 MHz channel bandwidth. PHY Speed 5764 Mbps (320MHz)
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.61 ms   (jitter: 0.29ms, low: 3.32ms, high: 3.97ms)
    Download:  2715.46 Mbps (data used: 4.8 GB)
                 13.33 ms   (jitter: 5.40ms, low: 3.17ms, high: 43.00ms)
      Upload:  1567.13 Mbps (data used: 2.8 GB)
                  7.68 ms   (jitter: 3.01ms, low: 2.69ms, high: 20.47ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/708e7d85-083c-4a71-95a1-d6a6e280ba88
2) 6GHz band, 160/80/40/20 MHz channel bandwidth. PHY Speed 2882 Mbps (160MHz)
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.74 ms   (jitter: 0.12ms, low: 3.52ms, high: 4.00ms)
    Download:  1842.57 Mbps (data used: 3.2 GB)
                 14.64 ms   (jitter: 5.58ms, low: 2.82ms, high: 30.66ms)
      Upload:  1222.18 Mbps (data used: 1.3 GB)
                  9.35 ms   (jitter: 3.79ms, low: 2.99ms, high: 21.19ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/2db6b6b6-6ac4-4026-988c-b5a8b5a7e83e
3) 6GHz band, 80/40/20 MHz channel bandwidth. PHY Speed 1441 Mbps (80MHz)
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.80 ms   (jitter: 0.95ms, low: 3.49ms, high: 5.48ms)
    Download:   953.76 Mbps (data used: 1.2 GB)
                 16.72 ms   (jitter: 6.75ms, low: 3.26ms, high: 45.49ms)
      Upload:   662.94 Mbps (data used: 853.0 MB)
                 18.49 ms   (jitter: 7.96ms, low: 4.12ms, high: 56.66ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/1d10e145-0938-4b28-96a6-c67ef538f983
BTW, TP-Link Archer BE805 WiFi 7 router FW 1.3 has fixed my MLO issues with Intel BE200 based Intel BE1750 WiFi 7 adapter. MLO SSID is now similar to 6GHz band in close range (3m distance tested).
TP-Link Archer BE805 triband WiFi 7 router, TP-Link stock FW, CH85, 5GHz+6GHz MLO,
6GHz band, 320/160/80/40/20 MHz channel bandwidth, CH85
5GHz band, 160/80/40/20 MHz channel bandwidth, CH60
PHY Speed 5764 Mbps (same as 6GHz band with 320MHz channel bandwidth)
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.49 ms   (jitter: 0.33ms, low: 3.37ms, high: 3.98ms)
    Download:  2639.44 Mbps (data used: 4.6 GB)
                 12.26 ms   (jitter: 5.19ms, low: 3.93ms, high: 32.14ms)
      Upload:  1545.14 Mbps (data used: 1.0 GB)
                  8.81 ms   (jitter: 2.66ms, low: 4.21ms, high: 23.87ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/a208e059-ddaf-488b-a138-cc3b03aa2de5
kappak
Which Phone Has The Fastest Wi-Fi 7? | iPhone 16 Pro Max, Pixel 10 Pro XL, S25 Ultra & OnePlus 13​
Iphone 17 speedtest
Looks like iPhone 17 series mobile phones with the Apple N1 wireless networking chip still do not support 320 MHz channel bandwidth on the 6GHz band.
But the speed seems to be better than iPhone 16 series. It could be now 4096 QAM is supported, increasing the max PHY speed to 2882 Mbps (iPhone 16 series do not support 4096 QAM, only 1024 QAM).
Need to wait for Apple to update the following website. Now it only has WiFi spec data until iPhone 16 series.
https://support.apple.com/en-sg/guide/deployment/dep268652e6c/web
Wi-Fi specification details for iPhone models​
Wi-Fi specifications for the following iPhone models are detailed in the table below: iPhone 16, iPhone 16 Plus, iPhone 16 Pro, iPhone 16 Pro Max. These models also support Wi-Fi 7 in the 2.4 GHz, 5 GHz and 6 GHz bands, and Multi-Link Operation (MLO).
802.11 standard, name, frequencyMaximum PHY data rateMaximum channel bandwidthMaximum MCS indexMaximum spatial streams / Type
be@6 GHz2400 Mbps160MHz11 (EHT)2/MIMO
be@5 GHz2400 Mbps160MHz11 (EHT)2/MIMO
be@2.4 GHz229 Mbps20MHz9 (EHT)2/MIMO
ax@6 GHz2400 Mbps160MHz11 (HE)2/MIMO
ax@5GHz2400 Mbps160MHz11 (HE)2/MIMO
ac@5GHz866 Mbps80MHz9 (VHT)2/MIMO
a/n@5GHz300 Mbps40MHz7 (HT)2/MIMO
ax@2.4GHz229 Mbps20MHz9 (HE)2/MIMO
b/g/n@2.4GHz144 Mbps20MHz7 (HT)2/MIMO
kimsix
iphone 17pm vs 15pm, both connect same 6ghz, stand right in front of eb810v
do you know if 16pm is faster than 15pm?
This one is supposed to come to Singapore soon -- based on MediaTek MT7927 chipset. So so sure about pricing, for Desktop only.
https://www.tp-link.com/sg/home-networking/adapter/archer-tbe550e/
https://einfoldtech.com/2024/02/tp-link-archer-tbe550e-be9300-wifi-7-bluetooth-5-4-pcie-adapter/
Seems to be available now, at about S$89.
Price is just for reference, from a quick search from SIM LIM Square Price List, on 4-Oct-2025
Example: https://www.laser.com.sg/price.pdf
There are many cheaper MT7925 based WiFi 7 adapters from Chinese vendors. There are also a few cheaper USB WiFi 7 adapters from Chinese vendors (eg: Comfast and Fenvi).
TP-Link WiFi 7 adapters:
https://www.tp-link.com/sg/home-networking/all-adapter/
1. TBE550E --> WiFi 7, PCIe, BE9300, MT7927 chipset, about S$89
6 GHz:​
11be: Up to 5760 Mbps(dynamic)​
11ax: Up t0 2402Mbps(dynamic)​
5 GHz:​
11be: Up to 2880 Mbps(dynamic)​
11ax: Up to 2402 Mbps(dynamic)​
2.4 GHz:​
11be: Up to 688 Mbps(dynamic)​
11ax: Up to 574 Mbps(dynamic)​
2. TBE400E --> WiFi 7, PCIe, BE6500, MT7925 chipset, about S$70. Price is on high side, cheaper to buy from Chinese vendors if you do not care about warranty.
https://www.tp-link.com/sg/home-networking/adapter/archer-tbe400e/
6 GHz:​
11be: Up to 2882 Mbps(dynamic)​
11ax: Up to 2402Mbps(dynamic)​
5 GHz:​
2.4 GHz:​
3. TBE400UH --> WiFi 7, USB, BE6500, high gain, about S$83, Realtek RTL8912U chipset, not recommended.
https://www.tp-link.com/sg/home-networking/adapter/archer-tbe400uh/
6 GHz:​
5 GHz:​
2.4 GHz:​
