Some data from Ubiquiti for the Dimension and Power Consumption Data (exclude PoE output if they have PoE function).
Need to get the Ubiquiti gear users to provide the typical power consumption data as the website only provides max power consumption data.
I will also try to collect some data from the Internet.
1) UCG, one of the most popular wired gateway
https://store.ui.com/us/en/category...ctions/cloud-gateway-fiber/products/ucg-fiber
Dimensions: 212.8 x 127.6 x 30 mm (8.3 x 5 x 0.5 ")
Max. Power Consumption: 29.4W (Excluding PoE output)
2) U7 Pro XGS
Dimensions: Ø215 x 32.5 mm (Ø8.5 x 1.3")
Max. Power Consumption: 29W
3) U7 Pro XG
Dimensions: Ø206 x 32.5 mm (Ø8.1 x 1.3")
Max. Power Consumption: 22W
4) U7 Pro Max
Dimensions: Ø206 x 46 mm (Ø8.1 x 1.8")
Max. Power Consumption: 25W
5) U7 Pro
Max. Power Consumption: 21W
6) U7 LR
Dimensions: Ø175.7 x 43 mm (Ø6.9 x 1.7")
Max. Power Consumption: 14W
7) U7 Lite
Dimensions: Ø171.5 x 33 mm (Ø6.8 x 1.3")
Max. Power Consumption: 13W
8) U6 Pro
Dimensions: Ø197 x 35 mm (Ø7.8 x 1.4")
9) U6+
Dimensions: Ø160 x 33 mm (Ø6.3 x 1.3")
Max. Power Consumption: 9W
