IIRC, for the 500Mbps plan, there is no cost penalty to remain on the plan without signing a new contract. The new plans now stipulate a "contract price" vs "non-contract price".I wanted to downgrade to 500mbps from 1 gb plan / wifi 6 router.
Contract ending may 2026.
Just realized both plans are not valid anymore.
M1 is offering free upgrade to 6 gb with wifi 7 router with 24 months contract.
To be honest, I don't require such speeds as 500mb is sufficient for my needs.
Any advise ? have been long time m1 user for 500mb due to reliability and affordable pricing
I had that fear so I signed early. I do regret it a bit as I don't need the router, and the 10Gbps plan price "dropped".i’ve been wanting to sign with m1 earlier on (cheaper price) but the cso told me not possible as the max they can hold an appointment is one month and my house is only ready in Dec.now it has increased by $5/mth.
I managed to delay the "fiber installation" for 6 weeks, and the ONT installation for 3 weeks after, a total of 9 weeks. I still ended up signing up for the plan 1mo early tho, so it is a bit of a bummer.
any idea of a wifi 7 router that has more than 3 x 10gbps ports? reason being, the first wan port will be taken up from ONT to router i presume, then another 1 port to do backhaul to another router as mesh/ap. 1 port directly to a data point to feed my PC via ethernet cable or is there no such thing? saw most routers have like 2.5gbps ports instead and only 1 x 10gbps wan port. That means those ports already capped the speed to 2.5gbps..defeating the purpose of getting a 10gbps plan?Meantime.... this M1 keeps enticing me with this offer:
Will surely jump if there is a breakthrough in TP-Link Archer BE805![]()
no surprise charges, all good for the last 2 month's bills.so did u get any nasty surprise? the contract clause make me uneasy...very disadvantage to consumer since there is rly a ONT guy coming down so if they wanna charge the $91 they can theoretically
nice!! thanksno surprise charges, all good for the last 2 month's bills.
I signed up for the 6gbps at 34.90 previously, now the 10gbps is that price. Is there no way to get that speed upgrade for existing 6gbps users?
why nobody sue these providers for false advertisements for 10gbps. haha..You get free router worth about S$300 with your 6Gbps plan at S$34.90 per month. For example, you can sell the Archer BE805 at S$240 (sure fast sell) and then the effective price of your 6Gbps plan is only S$24.90 per month.
New 10 Gbps plan is at S$34.90 per month, but without the router. The only gain is about 2.2Gbps increase in terms of bandwidth which is useless to 99.9% of the users.
Take note all the ISPs' 10Gbps plans are based on XGS-PON technology and will limit to about 8.2Gbps. They should be called 8Gbps plan in reality.
In fact I think your plan is much more worth it than the 10Gbps plan. M1 has increased the 6Gbps plan with router to S$38.90 per month for a reason. The extra 2.2Gbps bandwidth for the 10Gbps plan does not really cost M1 anything. The extra router for the 6Gbps plan does cost M1 some money.
Just upgraded to M1 Broadband 3Gbps with TUF AX6000. I understand that my router may not utilities 3GBps. Through lan cable , my network can hit 2gbps. However when it comes to wireless, the wifi can only hit 470mbps. Tested on iOS and Android, same result. Did I missed something in setting that I could bosst the wifi speed?
My offer's for 10Gbps at $34.90 (at 21 months) and option to add BE805 for $10 monthly.
I have enabled 160Mhz, reset the router. Disable QOS. Still doesn’t help so was wondering could it be the router is faulty. Or something I have missed in the configuration setting. Gonna try switch to 20Mhz.Just upgraded to M1 Broadband 3Gbps with TUF AX6000. I understand that my router may not utilities 3GBps. Through lan cable , my network can hit 2gbps. However when it comes to wireless, the wifi can only hit 470mbps. Tested on iOS and Android, same result. Did I missed something in setting that I could bosst the wifi speed?
