Xiaomi WiFi 7 and WiFi 6 Routers
Xiaomi router global version security update info -- not so good.
https://trust.mi.com/misrc/updates/detail?tab=iot
Product Name
Xiaomi Router BE3600 2.5G UK
Launch Date
2024-10-01
Security Update EOL Date
2027-01-12
Product Name
Xiaomi Mesh System BE3600 Pro
Launch Date
2024-12-31
2028-04-30
Product Name
Launch Date
2024-10-31
2027-10-31
Product Name
Xiaomi Mesh System AX3000 NE
Launch Date
2024-04-30
2027-03-05
Product Name
Xiaomi Router AX3000T
Launch Date
2024-02-01
2027-01-11
Product Name
Xiaomi Router AX1500
Launch Date
2024-02-29
2027-01-12
Product Name
Xiaomi Mesh System AC1200
Launch Date
2024-05-01
2027-03-31
mantians
Xiaomi BE5000 new firmware 1.0.91 is available since Aug-2025 on the website, but the router says no update found. Same for Mi home app and web browser UI. Anyone knows why?
You can always manually download and then upgrade.
https://www.miwifi.com/wap_download.html
I will try it with my Xiaomi BE5000 tonight to see how it goes.
Just downloaded the FW and used the Web UI to upgrade.
1. Before upgrade:
系统版本​
当前版本1.0.53,你的版本是最新的,无需升级。
2. Change log (no details at all).
Xiaomi路由器BE5000 稳定版 1.0.91(2025年8月27日更新)
尊敬的小米用户您好!此次产品更新内容如下:
已知问题修复
3. Upload the new FW and then upgrde the FW
4. After upgrade:
系统版本​
当前版本1.0.91,你的版本是最新的,无需升级。
Normal functions seem to be okay.
2.4GHz+5GHz MLO WiFi 7 Speedtest using my Acer Swift Go 14 2024 model (Intel Killer BE1750x WiFi 7 adapter).
One major problem is that the existing SSH does not work now, Need to try again. I was able to get SSH to work previously.
https://github.com/openwrt-xiaomi/xmir-patcher/issues/26
The other problem is that settings backup does not seem to work now. It does not seem to do anything after I click "start backup" button.
Take note I use this Xiaomi BE5000 only for testing purpose, so it is not important to me.
I wish it would have OpenWRT support in the future though.
1) The following SSH method does not seem to work with 1.0.91 FW version.
https://github.com/iamsxm/BE5000_SSh_UI
All the excution commands seem to be okay but SSH port is still closed.
Bash:
PS C:\work\networking\xiaomi> ssh root@192.168.31.1 -p 23323
ssh: connect to host 192.168.31.1 port 23323: Connection refused
2) I remember the following method worked for Xiaomi BE5000 1.0.53 FW, now it does not work with 1.0.91 FW.
Bash:
(py312venv) PS C:\work\networking\xiaomi\BE5000_GetShell> python .\crack.py
Start retriving SSH permission.
(hang here).
Xiaomi China WiFi 7 router current pricing for reference.
Need to wait a bit for the real 11.11 offer.
BTW, Xiaomi Taobao/Tmall Flagship Store may have slightly better pricing but not so much as of now.
https://m.mi.com/commodity/list/2458?spmref=&scmref=
Xiaomi BE3600 2.5G version, RMB 199
Xiaomi BE3600 Pro two-pack (main plus mesh node), RMB 699
Xiaomi BE5000, RMB 279
Xiaomi BE6500, RMB 449
Xiaomi BE6500 Pro, RMB 599
Xiaomi BE7000, RMB 799
Xiaom BE10000, RMB 1599
Xiaomi BE10000 Pro, RMB 1699
mantians
Thanks for the info.
So far I do not have any issue with 1.0.53, so not sure if should upgrade to new FW. I don't use advance feature like SSH. Is it possible to quickly rollback to previous FW after upgrade?
mantians
Strangely can't seem to find the BE6500 on Xiaomi Taobao Flagship Store. Don't think so fast phased out?
I tend to think Xiaomi has not phased out Xiaomi BE6500 as it is still available from 小米商城 at RMB 449.
Maybe they have limited stock and want to promote their own online shop.
EeeK
is it expensive to manufacture 10gb port or the chipset controller? why we have limited 10gbs ports in our current available routers?
network port goes from 100mbps to 1gbps and the next should be 10gbs, duno why this 2.5gbps came up.
Yes, 10Gbe PHY and Switch chips are expensive. So you only see two 10Gbe ports on typical consumer WiFi 7 routers.
Even the top of the line Asus ROG GT-BE98 has only two 10Gbe ports.
2.5Gbe ports are a good compromise. It is not expensive for the router vendor to add 2.5Gbe ports now. It is also cheap for the client devices to add 2.5Gbe ports.
You can take a look at the top of the line motherboards, you seldom see 10Gbe port, but rather only 2.5Gbe port (or 5Gbe port recently).
