Habrosus
- Jul 23, 2005
Still missing.Restart your phone![]()
iPhone?Still missing.![]()
Yup! And eSIM so I can't move it.iPhone?
i just receive update for the app on my android phone, let me try to update.Yup! And eSIM so I can't move it.![]()
Just updated the app, and that option seems gone, i also cannot use the old version of maxx.i just receive update for the app on my android phone, let me try to update.
Yup option missing on 28 Oct version of the app.Just updated the app, and that option seems gone, i also cannot use the old version of maxx.
https://maxx.sg/numbertransfer-port-in
On the website, it says must use the app
Option gone from mine too, v.2.4.0.We can no longer port in another telco's number to an existing Maxx line?
Or is it because it's a retailer's non-recurring plan?
Or maybe they're really craving for people to talk to?![]()
Not say M1 maxx more stable, more like depends on location.You mean for your case M1 maxx more stable ah??
yup there are certain places ST MVNO cmi, especially peak hours on MRT trains, the network is so congested. This is where M1's 5G SA is king, on CCL, i was able to stream videos and surf websites without lagging. ST MVNO like zero1 and zym starts lagging.Not say M1 maxx more stable, more like depends on location.
Some place M1 maxx better, some ST MVNO better.
Any report on nsl towards cbd?yup there are certain places ST MVNO cmi, especially peak hours on MRT trains, the network is so congested. This is where M1's 5G SA is king, on CCL, i was able to stream videos and surf websites without lagging. ST MVNO like zero1 and zym starts lagging.
Best to have both worlds. In terms of RAW speeds, M1 Maxx still the best as compared to ST 5G NSA. So far haven't tried ST 5G SA, so cannot compare.
for maxx? I don't travel on NSL, so can't report on itAny report on nsl towards cbd?
Guess I need to test more places and feedback more haha.. before it downgrades to base plan...Not say M1 maxx more stable, more like depends on location.
We can no longer port in another telco's number to an existing Maxx line?![]()
Or is it because it's a retailer's non-recurring plan?![]()
I did a couple of times before too, just that wanted to port a line this morning and couldn't find the option.worked about 2 months ago. Maybe something changed since.
the existing number was a non-recurring line, purchased 6 months prior from my friendly neighbourhood Beng Shop. It was on base plan, so just bought a 1 month 4G plan and ported in on a Friday evening. Successfully ported by Sat morning.
they are humans, so human contact is vital, no?![]()
For queries and such, customers would appreciate the human touch. But to terminate a line, they could've let us do it online, either a form (like Simba) or an email (like Eight). Having to call them would mean having to go through their verification steps too, like call my other Maxx line.
Touch too much also no good.![]()
AFAIK, max 2 lines active. So it's either 1 physical with 1 eSIM, or 2 eSIMs active at the same time. Don't think you can have 3 lines running...Ok I just signed up for the $10 sa plan. Later take Mrt hopefully can scroll my phone and not watch people scrolling .
im pairing this with vivifi $7.70. Is there any cheaper than vivifi 7.70 out there? Thinking of reducing the overall cost.
also, never use dual sim before as this is my first time. So can I ask - I’m using vivifi physical, maxx esim. I need to set my phone call and sms to remain as vivifi then for data I need to allow data switching correct? Anything else I need to be aware of?
then say I go overseas (say Nz) and buy airalo eSIM for data. Does it mean I load airalo eSIM then I can use vivifi, maxx and airalo? I’m on iPhone 16 pro btw.
Oh sorry didn’t know. So if I go overseas, I keep vivifi (main) to receive sms and calls from sg. Then once I load airalo, I need to “turn off” maxx, that right assumption?AFAIK, max 2 lines active. So it's either 1 physical with 1 eSIM, or 2 eSIMs active at the same time. Don't think you can have 3 lines running...
