Oppo Find X9 Series
Ariobeth
One thing I noticed, adjusting the smallest width settings in developer options doesn't retain after you reboot phone. 🙃
It is the same in past version of android. It is just a temporary settings. need to re-set it again after reboot,
007Mi6
Anyone tried the OTG? May I know what’s the transfer speed like? Wanna use this photo for my backpacking and transfer to SD card etc along the way.
crow_nest
Is this an Oppo thing? cos Ive been using a custom width on my P9PXL and P10P all this while and it never resets
stupidog
bought this case from oppo shopee
007Mi6
Wah went to Suntec outlet. When they knew I got my Oppo Find X9 Pro, the attitude changed sia. Was looking for teleconverter and if buy as bundle $229, buy separate is $299. On backlog order until mid November for those interested.
Shadowz1984
No can buy x9 pro from Lazada at $1070 if you have $130 worth of Lazcoins.
Exaita
My friend say china immirgrant ask her to open up the box coz got battery inside
symbiote28
how's the wireless charging? if i'm using a Qi2.2, that means im only getting 25W? only the oppo wireless charger can get the 50W
anizee
anyone having trouble adding credit cards to Google pay? Keeps giving me an error that card couldn't be added, even though it worked fine on my other phones.
rinchan22
is it cause you just change phone and got the 12 hour cooldown for some banks?
Ariobeth
Correct, same with oppo store. i have pre-order @ $229.
Ariobeth
I have unlnow brand 10KmAh wireless charger of around +22w i think. so it is basically charging slowing. It works tho. even the freebies of 5KmAh charge around + 10w.
Exaita
they no comission ma hahaha
Ariobeth
no problem for me. tho hearsay in some other countries same thing. some cards just cannot add and work. sometimes it was a bank settings nowadays for spam protection, they turn it off. you have to turn it ON temporary timing only and then add card from Google pay.
chari-men
Why u didn't buy with the phone??
