Oppo Find X9 Series
KeYoKe
Hi, I have both iPhone and Oppo X9 Pro. I can transfer from Oppo to iPhone using O+ Connect app. But I dunno how to do it from iPhone to Oppo. Is it even possible?
Search for Oppo clone app on appstore and follow the instructions from there
007Mi6
yes, it lets u just clone photos and videos only too, it should let u select which category of things to clone over
thanks for sharing.
what I mean is both iPhone and Oppo X9 pro are already setup.
sometimes I take photo on iPhone and sometimes on Oppo.
after taking photo on iPhone I want to transfer to Oppo. Currently I can transfer from Oppo to iPhone after install O+ Connect on Oppo. But I need to know if I can transfer from iPhone to Oppo
tkte_85
thanks for sharing.
Ya, u can do this task anytime, even 5 years after u use the phone. Just that u cannot choose specific photos. And tbh your case I'd just say use Google photo to sync your iphone camera shots, they will be accessible in any device, even your PC
Bingo. @KeYoKe
Suspect number 1 caught.
Under sim card status, your sim is being split into 2 category. Both NR and LTE. For some reasons, by right it should only be ON for the strongest network available. NR or LTE, it should not be both at a go.
Sorry... Don't really understand what you are trying to say here...
KeYoKe
Mobile network type:
LTE & NR
Signal strength:
LTE has readings
NR nothing
Is there a way to only enable one over another?
You are connected to WiFi.
Disable WiFi you will see readings on both.
According to @royfrosty , it should only show reading on 1 of it only, depending on whether it is connected to 4G or 5G. It cannot be both.
ranmaru1987
According to
@royfrosty
I disable or enable wifi also have reading on both leh..
kashix
Bingo. @KeYoKe
Mine is also both at the same time
royfrosty
Yeap. As long you turn on wifi.
Your NR will turn off. And only connect to 4G for voice.
But the moment you off the wifi. Both 4G and NR is connected. Meaning to say, your data runs on NR, your voice runs on 4G. It's a config done by all Singtel MVNO. Which will affect a bit more battery usage in background. By right you are only suppose to be connected to 5G NR or LTE only.
therat
Am I the only one who feels like oppo don't really push phone updates? If I'm not wrong, think launch only have 1 update on/around the launch day? Meanwhile I lost count on how many updates I received on vivo x200 ultra.
dont think so.
When I'm using Find X5 pro, I receive quite a number of updates.
many updates - devolopment team very ON. Keep inline with techonology OR mean alot of bugs?
No update - the devolopment team didn't update any patch OR OS is up to date with techonology?
Depend which side looking at
kashix
No wonder my idling drain is more hiong on GOMO.
