Oppo Find X9 Series
royfrosty
Op15 for performance
X9P for the ... Hasselblad rendering
X300p for the Zeiss rendering
If this is unclear then I don't know le lol
silverstone
Mobile network type:
LTE & NR
Signal strength:
LTE has readings
NR nothing
Is there a way to only enable one over another?
You are connected to WiFi.
Disable WiFi you will see readings on both.
According to @royfrosty , it should only show reading on 1 of it only, depending on whether it is connected to 4G or 5G. It cannot be both.
Yeap. As long you turn on wifi.
Your NR will turn off. And only connect to 4G for voice.
But the moment you off the wifi. Both 4G and NR is connected. Meaning to say, your data runs on NR, your voice runs on 4G. It's a config done by all Singtel MVNO. Which will affect a bit more battery usage in background. By right you are only suppose to be connected to 5G NR or LTE only.
thats cause y'all are connected to singtel 5G NSA network, hence it has reading for LTE and NR. if u are connected to 5G SA network, then it will only show NR.
singtel MVNo like zero 1, ZYM and vivifi does not have SA network yet.
masashi
Wonder if I can still use the teleconverter kit after applying the tempered glass on the back cameras. May consider getting it in the future:s34:
symbiote28
anyone bought from singtel online without plan? i still haven't gotten the freebies and it's almost 3 weeks now.
masashi
Oppo just pm in shopee about the availability of the teleconverter kit just now. Speaking of timing. Plus it's selling at $229. Might as well use the other voucher to make it cheaper:s34:
crow_nest
What voucher did you get to bring it down to $229? Cos Im thinking of getting the kit now too. I bought during PO period and never got a voucher for it
EDIT: nvm just saw my shopee DM's, they sent me a code since the kit is back in stock
