M1 Maxx (maxx.sg) Discussion
IMHO.
Alamak, my M1 Maxx in router no data ! :mad:
Hmm, your router has the airplane ✈️ mode or not?
My side no problem, at home now (Jurong West Area), Poco X7 Pro, M1 Maxx S$10 plan.
It is comparable to SingTel SIM Only S$15.28 plan.
keenklee
IMHO.
I think my end a lot of users. The connection recovered by itself with no intervention - so unlikely is in airplane mode. But ok, i have 3 mobile router, Heya 4G, Zym 5G and M1 Maxx 5G - just switch over. :ROFLMAO:
IMHO.
That is triple redudancy. Good.
How many mobile numbers you have now? >12? :LOL:
Do you still have Fibre Broadband now?
keenklee
reboot router lo
IMHO.
I suspect the router not SA compatible. :ROFLMAO:
But previously was ok as I could get might higher speed. 🤔
I had 2 same router.
I found something very interesting.
1st router i bought firmware version 1.2.1 build 20250413 rel 44588 - box is ver 1.0
2nd router i bought firmware version 1.1.0 build 20250719 rel 59911 - box is EU/2.0
:ROFLMAO:
keenklee
IMHO.
At my this location, I don't have fiber BB - i have to survive with mobile broadband.
I have in total 4 - 2x x50-5G (active) , 1x x10-4G (active) and 1xGL.inet Beryl AX (tether) (non-active) excluding workplace primitive Prolink (active).
IMHO.
:ROFLMAO:
IMHO.
TP-Link Deco X50-5G is supposed to be compatible with both 5G SA and 5G NSA.
But there are reports of issues connecting to 5G SA network.
https://community.tp-link.com/en/home/forum/topic/676484
I have not opened the Deco X50-5G router bought from Shopee TP-Link Store with the 11.11 promotion yet, along with two other 5G routers bought from Taobao ( portable ZTE brand, and lower end ZLT brand from GZTOZED).
keenklee
IMHO.
I had initial hesitation of the Deco x50-5g working in SA because of the little information on it.
IIRC, I read something on something like how SA does the handshaking which may have compatibility issue.
My Samsung A14 5G - cannot work with M1 Maxx SA but I got top speed with Singtel NSA.
Initially, I already have an Deco x50-5g on Zym which provided NSA which was supposed to have ended but because I did not turn off the router, I was still getting NSA. :ROFLMAO:
So with that hesitation, i still got another got another deco x50-5G for SA and it worked. I could get very good speed with it initially. Somehow, the performance getting worse.
I just need another SA sim card to verify. :ROFLMAO:
keenklee
IMHO.
I think you should take it out and test. :ROFLMAO:
Should I feel lucky I don't use Taobao ? :ROFLMAO:
sallybee
I have TV connected to the Internet as well as pc at home connected via WiFi
If I change to mobile router, is it gonna work?
How much are these mobile routers
IMHO.
Yes I will test them.
I just Just received one portable ZLT X35 5G router from Taobao.
Now I got two 5G fixed routers and two portable 5G routers. Only the Deco X50-5G is from Shopee. The other three are from Taobao, one is ZTE brand, two are ZLT brand.
it_geek
Hi folks,
I am currently on the Maxx 7.90 auto renewal promo (last promo month before reverting to 9.90), is it possible to cancel the main plan and just have the base plan only?
Hi folks,
Call 1693 and they should be able to help, as per previous post from loganrunning.
it_geek
I checked his posts in this thread, and seems like he bought the plan from a physical retailer.
Mine is the online exclusive promo, so I am not sure if it can be done the same way.
gapboy
The support for Maxx works under one hotline. Give it a try, you wont know if you never try .
gapboy
Eevn though I am porting out of M1 Maxx to CUniq, I may port it back to M1 Maxx after the trip to China.
One thing I like is the 1693 hotline, which seems to be pretty decent, the CSOs sound like from local or maybe Malaysia.
I have called 1693 twice and I feel the service is good.
Avoid calling in peak hours. Usually, the line is available within 5-10mins
keenklee
IMHO.
Please let me know what you both call about - so i can call and try.
Erm...cannot be i call them and ask them why my location so slow ? :ROFLMAO:
