Maybank Family and Friends grocery casback
mirage_77
Seems like the Transport section is also split into Commute (Bus/MRT + new Batam Ferry etc) and Automotive (Petrol Stations).
I use this category for Grab/MRT and Petrol top-up at times when i pumping at SPC. Looks like I need to rethink my selected categories.
Imhthc
This card is still useful to me albeit a reduction to 6% on $800 spent provided they dun remove the other categories I used and easy to clock for eg dining including fast food and online purchases. Seem like the mcc for these categories are not declared. If these categories are also nerfed, I will seriously thinking of jump ship to Citi
GrandJedi
Something wrong with the Treats benefit optimizer for November? My shows $312.50 in 2 categories.. Unlikely for me to be so accurate with my spending....
GrandJedi
Did u use ur card for IDR / MYR spent in Nov?
Yes... I also noticed that the benefit optimizer app also works funny.. when I add up all the spend in the categories (including other spend), it is more that Total Spend Number at the top in the circle!
jtec14
I thought their dining category exclude fast food restaurants?
Imhthc
Since you spent in MYR/IDR, the top categories will be filled up first before the remaining goes to MYR/IDR categories hence it is common to see $312.50 (capped for each category).
for eg, $200 spent on food in sgd and u spent another $180 in MYR for the same category, in the optimizer, it will show $312.50 in the food category and $380-$312.50=$67.50 will appear in MYR/IDR.
Imhthc
Look closer. It could be cases when ur spent is eligible for other spend but does not account for eligible for the monthly total spent. If the total spent amount has already reached $800 and above, it’s not a concern as you will still receive the 8% for the categories you enrolled for.
cerato79
Quite sad that there is no more pharmacy. So watsons and guardian pharmacy no more liao.. If I buy watsons in Malaysia, this will count towards MYR spend right? But SG no more liao 😕
Imhthc
As long as it is in MYR spend, it will count in MYR/IDR category. Useful if you shop in MYR regularly and can clock S$800 with this card for that month
vsvs24
At least a week for me liao, either otp smses took much longer to come or the app just stuck after keying in otp.
Happened to me since long ago on my banking phone. In the end I always use another phone to check.
