Vivo X300 series
Kitaro9202
mine using kadas lock , try to connect my phone to lock for registration but fail,
but use my card able to detect and clone it
chari-men
Might consider switching back to the smaller x300 from oppo x9 pro as my secondary phone.. the night shots from x9 pro a bit cmi.. and also for fast motion pics..
Jurong640
X300s coming soon. Bigger battery with better processor
vivo X300s to deliver a massive upgrade over the X300's battery capacity
It will pack a 7,000 mAh battery, which would be a significant leap compared to the X300's 6,040 mAh cell. The X300s should employ the upcoming MediaTek Dimensity 9500+ SoC, which, if history repeats itself, should be a very small iterative upgrade to the 9500 - if you think of it as a higher-bin 9500, you're probably not wrong.
Blueberrytea
The x300 pro might be the poison to stop me going for s26 ultra...having own every single ultra since s20 ultra, I sincerely feel Samy need to step up their game alot
chari-men
See what's the price difference lo lol.. definitely a china only released tho..
Jurong640
This month china going to release Vivo S50 and S50 Pro mini m when come global, the S50 Pro mini will most likely be rebranded as Vivo X300FE.
I was on JD.com app and saw the sneek peak of the S50 which will be rebranded X300FE, look like the iPhone Air and Honor 500 Pro
hstreamy
Under wallet app payment settings , access card not set as default right ?
I tried many times I suspect is my case too thick...I remove case and scan almost everything can as need damn near til touch sensor then can detect...with my nilkin case on I move up and down also hard to detect
So conclusion not that useful to me unless I'm using my phone naked or fall back to fingerprint direct unlock faster😅
Yeah,am using caseless, with just skin at the back
chari-men
FE is budget series.. definitely won't be as capable as the main x300 series in camera one..
Jurong640
Same boat. I wanted to get S26 Ultra to replace my current S23 Ultra. But the recent development and leaks, don't really entice me to "upgrade to S26 Ultra". They are retaining same hardware. S23 Ultra was the peak with 10x zoom.
I'm still considering if i should sell away my S23 Ultra (with 10x zoom) or S24.
Blueberrytea
Guess faster sell b4 green or pink line appears ba
Am glad x300 pro screen from BOE not samy😅
ZhuTou!
Why x300 is smaller compare to x9p :s13:
