SingTel 3Gbps, 5Gbps & 10 Gbps Enhanced
kurogane
1) The 5Gbps recontract offer is a decent one at S$29.90 per month with free HB611-SGST.
https://www.singtel.com/personal/products-services/broadband/eform/recon-edm/5gbps-plan
5Gbps Enhanced Plan at $29.90/mth (U.P. $70.90/mth)
Comes with 1 x Singtel WiFi 7 (TP-Link BE11000) Router
Previous recontract offer reported.
2) 3Gbps at S$29.90 per month with free HB611-SGST. Not many users got this offer through recontract. It was mainly a targeted offer for new SingTel Fibre Internet user with existing SingTel mobile service.
3) 3Gbps at S$39.90 per month with free two nodes of HB611-SGST.
4) 3Gbps at S$39.90 per month with free HB611-SGST, and then S$120 or S$240 voucher.
I am not so sure if the following user manages to get so high S$240 voucher. Usually the voucher amount is much less at about S$120.
For the record this was the selection when i decided to go ahead with the recontract.
They are coming to do the installation this week, hope it will be a better experience this time round,
<<Select your preferred plan (24-month contract):
3Gbps Enhanced Plan at $39.90/mth (U.P. $55.90/mth) + FREE $240 FairPrice Voucher
  • Comes with 1 x Singtel WiFi 7 Router (TP-Link HB611)>>
jess_sy
So this is 3gbps or 5gbps?
But i think either one it's good enough for $29.90
Real usage not much difference
1. 5Gbps if you talk about the first link.
5Gbps recontract at S$29.90 per month with free HB611-SGST.
2) As for the one with S$240 voucher, it is 3Gbps. Effective price is at S$29.90 per month with free HB710.
One more report in this page.
3) As you mentioned, no real world difference for most users between 3Gbps and 5Gbps, or even 10Gbps.
hi guys,
currently have 1gbps plan and contract just ended and monthly bill increased.
1) wanna check currently is there anymore 1gbps plans to recontract?
2) i check singtel page only have 3gbps and 5gbps plan currently, if i recontract to those plans will i need to swap any router etc or my exisiting router can use and fetch the 3 or 5gbps?
3) i currently using the ONT, if i change to 3 or 5gbps plans need to change to the ONR? if i dont want to change ONR and stay ONT still can get 3 or 5gbps?
thank you.
hi guys,
thank you.
1) No more.
2) What is your existing router?
3) No, your ONT cannot be used. They will change your GPON ONT to XGS-PON ONR.
Recommendation is to go with M1 or StarHub, if you want to get ONT.
Thanks man
Router i think is Singtel WiFi Gigabit Router AC Plus, the standing black colour last time one
anyone know if this link is still working?
1) Hmm, AC Plus is an old SingTel issued router and out of security update (until 30 November 2024). It is better to upgrade now.
https://www.singtel.com/personal/support/broadband/troubleshoot-by-router/ac-plus
For ONT users, once you use the old SingTel issued router, you lose all the benefits of using an ONT.
2) Singtel XGS-ONR + HB611-SGST is actually much better than ONT+AC Plus.
3) Somehow your link is not working.
But the following link seems to work now.
Singtel Fibre Broadband plan​
(24-month contract)
Fibre Plan includes:
  • Home Line
  • 12 FREE months of Amazon Prime subscription (U.P. $4.99/mth applies thereafter)
  • 12 FREE months of Broadband Protect subscription (U.P. $3/mth applies thereafter)
  • 6 FREE months of HBO Max Standard subscription (U.P. $14.48/mth applies thereafter)
5Gbps Enhanced (WiFi 7) Plan at $29.90/mth (U.P. $70.90/mth)
  • Comes with 1 x Singtel WiFi 7 (TP-Link BE11000) Router
