Anyone here staying in 2 room BTO?
Should we move it to HomeSeekers and HomeMakers?
  • Total voters
    49
  • Poll closed .
The_King
He knocked down the wall for the little niche to combine with the bedroom?
Also is it possible to place a wifi router in the living room instead of sticking in the DB cabinet:s22:
Can, you have to lay the patch cord to living room.
I diy mine with 2 patch core in case 1 gg
Can see my picture on how I lay fiber from db to living room, it like practical aka brutalist theme
The_King
24k .. iniside the chat.
many carpentry...and remove wall.
kitchen nice... open concept... look very big
Open concept is bky.
Too much carpentry cannot due to the VOC which can offgas even after 5 yr
Mine 2 processed wood furnished already can Smell the chemical ( the storage bed plywood and the IKEA cupboard) even after 2yr
I cook and when I cook I switch on fan, open 2 door. Living room door closed, bomb room, toilet door all closed
yokine3a
not doing reno... just paint and live.
As for furniture, just measure and plan after key collection.
The drain, aircon/water/gas piping, socket, switches location are not shown on floor plan.
the only hard issue i will face is the kitchen layout.......
-how to dry my clothes
-how to exhaust the fumes when i cook
-installing top cabinet for my kitchen appliances or just dump inside store room.
Get a powerful cooking hood.
I might go for modular top n bottom cabinets, instead of built-in. If spoil, just throw n buy new one.
The_King
Ur kitchen is those long shape?
cplbao
King. Can I ask you if new BTO HDB got default patch cord to room/ kitchen?
wongminmin
If mine is easy use rack as support or wall fan to blow out the oil smoke
i thinking air dryer or drying rack at living room (facing sun). then built the stove near window and use fan to blow out.
but i see ur layout is sink near window.... most likely the drain pipe is near window. :censored:
Langrisser999
Bus is only as reliable as their schedule. If bus interval ****** up, I'd rather take the LRT. sometimes waiting for a 2nd LRT is still faster than waiting for a bus especially during off peak.
Not really leh, got one time from waiting, boarding and reach punggol centre. It took me almost 20 mins. last sat, I walked to punggol coast MRT and took the train and reach kallang MRT within 45min, if I took LRT to Punggol than change to MRT will be over 1hr.
The_King
Drying rack at living room Why
Stove near windows is good idea but ppl will hate it but it a cheap way to get tdmoke out so why not
Ya Drain pipe beside windows
The_King
dont have, i diy pull from DB to living room,
ont, router, pfsense, dac all in 1 shelf
me use the amoured version, not sure any tougher. but i install 2
XiaomiMax2021
i can take both direction ...LRT .
King shd know well.
The_King
Sharing what i know and learn so far, i try make it in point form to keep it simple:
contact 4 company:
letscool
amyth
aircon rescue
newway
my shortlist are simple:
look at google bad review (or any other source) only, the bad review date last posted how often bad review is posted
materials
materials :
letscool quote me : SWG22
amyth quote me : SWG22
aircon rescue quote me : SWG21
newway quote me : SWG21
the price all 4 are less then $40 different
all other almost the same of 1/2inch, copper wire almost same core and number of wire etc..... so my shortlisted are aircon rescue and newway as they quote me the correct materials (i started a thread talking about the copper thickness)
i choose newway based on google (or any other source) bad review feedback or lack of (as explain) aircon rescue no cause not much of any feedback from any source (it a new company)
after the piping is 80% done, i go take picture . i take this drain pipe like very little insulation when he saw me take picture he redo (or maybe he already want to redo i dont know) but happy he did redo cause the next 3 to 4hr doing the piping from 3.30pm until 6.30 to 7pm++++++
more checking, so far so good after that strange redo
from here on, all is good, everything is good, dont even need to open mouth liao
drain pipe no join connector but using heat to pipe and install with insulation at blend area
video about layout(before drain pipe redo), vacuum and doing the soap test to check leak , installer auto use soap to check for leak on their own unlike my first installer who dont even vacuum and do the soap test
video link:
https ://imgur. com/7fYCGkg
https ://i.imgur. com /7fYCGkg. mp4
last step, they even add rubber on the condenser leg, (this is not needed at all, some may first it a cons if the rubber wear out) i feel adding it, doing the soap test show their professionalism
workmanship issues take time to show up, can be weeks to year. but so far everything look good for now
