Mr.Canberra
- May 22, 2014
got from TB la, to store battery
I thought you are explosive specialist leh!
Now at Canberra Vista.
Many people moved in already. 5-Room flat residents huat liao as MRT station is just at doorstep. 5 years later become millionaires! Don't even have to cross the road.
Do u have plan to do customize db shelf?DB Box - M1 ONT and charging point
Table - Router and stuffs. If I put the wifi router at DB box, the reception is weak
Can you try to untangle and do cable management? MessyDB Box - M1 ONT and charging point
Going to be a long wait for mine 🫣Good place to go JB and Yishun![]()
just buy this kind?Do u have plan to do customize db shelf?
Me using rack but like lot of wasted space
what is this box for?
my wall side is like a M shape, so the rack have to be even smallerjust buy this kind?
to store anything that is fire risk, in short anything have battery will be stored herewhat is this box for?
got arh, u go tb and search this picture..... got smaller width 1.my wall side is like a M shape, so the rack have to be even smaller
i can find just that i need front and back space like wastedgot arh, u go tb and search this picture..... got smaller width 1.
i find this quite handy.... just cannot put heavy stuff on it. The extendable pole is spring loaded.
then customize from taobao ba....i can find just that i need front and back space like wasted
put shoe also need sideway, if customize then no issues and dust dont drop all the way to bottom
this one kiv for futurethen customize from taobao ba....
local customization is really exp![]()
