Android Tablet Setup for Elderly Parents
nez
I've got an Android tablet for my elderly parents to consume media like YouTube.
Since I don't stay with them, what's the best way to set it up before giving it to them?
Specifically, for the Google Play Store, should I log into my own Google account to download apps, or should I create a separate Google account for them?
Additionally, are there other setup steps I should complete beforehand?
Any preferred setting I should use for the elderly?
Thanks
nez
Create a dummy account safer. If they kana scam wont affect your gmail etc.
oh. Ok.
Then ok to use their own google account?
I set their gmail account for them previously for email purposly only.
Can I use that or really need to create a seperate account just for apps?
Thanks
froztheart
Thanks
Everything should be isolated, and you can login on your device still for MFA authentication, security changes etc. for Google too.
oh. Ok.
Thanks
Yes, use the one for email purpose works fine too.
Check the settings to have everything like security settings etc. setup and done so to reduce risk to minimal.
Importantly educate them to not anyhow download etc. too.
nez
Thanks. What do you mean this the above?
nez
Sorry, I don't quite get you.
What do you mean?
In what context?
are you refering to if I use my personal google account on their device, it will not affect me when i login on to my same google account on own devices?
or what are you refering to?
froztheart
In what context?
Basically, use your existing gmail to setup the tablet.
Then login to your devices so that any login/user account controls, settings etc. you can monitor since it will be prompted.
Devies locally will need you to educate them to not anyhow download/click links and check with you if unsure.
caterham7
Thanks
education is key, can consider the resources here
https://www.imda.gov.sg/how-we-can-help/seniors-go-digital
also, do regular checks on the tablet, to make sure no dodgy apps installed
if possible, teach them to access youtube via firefox browser; help install ublock origin extension, as it removes ads from most websites
also enable private dns in android settings
if they prefer to use their "mother tongue" to search, type, etc., help them to install the respective keyboard language
debloat and remove apps not needed
nez
Got it. Thanks
nez
Got it. WIll use firefox browser to install youtbe.
What should I change the private dns in android settings to?
Thanks
froztheart
Do regularly check-ins for their devices to ensure no funny apps, and possibly run through their chat app likes WhatsApp, stock SMS apps etc. too if applicable, to ensure they are not getting scammed unnoticed.
Turn on all protection settings for Google too on the device.
nez
Thanks.
I will not be installing any messaging apps. This is purely for media consumption.
Anyway for me to remotely check their devices?
froztheart
Thanks.
I use AnyDesk but requires setup first. And as with all remote devices, sometime still need physical access to reset/reboot connectivity.
