Oppo Find X9 Series
rainbow99
Hi all, I'm using private DNS and having been getting the following error message every day at least once, usually in the morning when I check the phone after waking. I don't have such regular messages in my previous phones. Is this a bug or I need to tweak some settings. thanks.
Failed to connect to the private DNS server. Please turn off Private DNS to connect to the internet.
kashix
I kena before recently but after that no problem le
SPEED
For those who got Telco sets of x9 pro, are there any Telco apps inside one? Or it's the same apps like from Oppo retail sets?
tohchr
Telco SIM card inserted, all the bloatwares will be installed. Use Adb to uninstall it
Shadowz1984
Telco set is sealed one or what? How does it works? Warranty?
Telco sets typically is people recontract then don't want the phone and sell to shop.
Those that recontract at physical shops the sets will typically be opened by the telco on the spot for you to check.
So warranty typically already started since the phone is opened and on already.
That's the reason why telco sets typically are cheaper.
tkte_85
telco set if collected in person, its mostly unsealed and activated at time of recontract and sold to the shop. So warrenty starts from date of recontract. But if its through delivery, its most probably still sealed as the delivery just delivers, they usually do not open up the set. But the activation i cannot confirm if its thru telco or thru 1st login+use
